I though since people throw out microwaves far more than Neon signs an easy solution is to use a MOT. A large number of people say it is not possible to build one with only one MOT, or at least some form of voltage multiplier circuit.
a MOT puts out only 2k and over 500mA (A cap on the low voltage side will limit current)
Well it is possible to build a tesla using a single magnetron microwave (It is disappointingly weak though, an ignition transformer from a car puts out more juice, and is my preferred tesla coil transformer) I got about a 1cm spark, but it throws RF like crazy. It is a semi decent beginner coil being made mostly from scrap, and needing no power transistor drive circuit.
Remove these ads by
Signing UpStep 1The Circuit
A MOT will jump the spark gap, but it will not jump it in a coil circuit. To let it build the voltage I used a diode. The diode does not let the cap discharge. So the voltage may build and jump the gap. (Still appears to fire each AC cycle) It is not a voltage multiplier just a rectifier. A multiplier would improve the output considerably but cannot be made with one Microwave.
WARNING USING THE DIODE ALOWS THE CAP TO KEEP ITS CHARGE FOR SEVERAL MINUTES AFTER USE
There is a built in resistor in most microwave caps but please short the terminals anyway before servicing
(should go without saying) the same with the ballast cap.
I'm still leaning toward ignition transformers.(already have one)
Of course I blew through 10+ 555's and 4 CD4047BE's driving one. (PC123 might help)
I've got plenty of power transistors though.
What was the kV of the NST you got? I would settle for 7.5 but would rather have 10-15kV (then I would need better caps too)
bad enough I do not touch anything near them while it is on. I'm ok with high voltage (still get shocked pretty often), but better safe than sorry.
If I could find a cheap GCFI I wonder how hard it would be to bypass. If the case opens it really should not be a problem. It probably is not the best idea in the world, but neither is an un-ballast MOT.(of course I sort of current limited mine)
I always install a bleed resistor(or use caps with them built
In like MOT caps) and cover the Cap bank. I think a manual discharge
Through an inductor and low value high watt resistor
may be a good idea.
the GCFI probably is epoxyed into the case
(for safety) and I will avoid them.
If the gap fires regularly then it is most likely a problem with the air core transformer.
The HV cap is not charging. (or does not work)
Make sure it is connected in parallel with the MOT out (through the diode), and if it is take it out and test it. (short it first just in case) If you do not have a cap meter charge it with a low voltage (12V or less DC). Then test for voltage a minute or so after charging.
(working microwave, working magnatron, sounds fun)
It defiantly needs more power for corona.
It does not have enough voltage to produce streamers. It should arc if you ground another rod and place it 2-3cm from the top load.
You can get more voltage from the MOT if use add a voltage multiplier or use to MOT’s series aiding. (once I get another MOT I will try series aiding and a cascade)
Hook the diode to one MOT lead (since it is a half wave rectifier polarity is not important)
The other MOT lead will hook to the cap
Then hook the remaining diode lead to the remaining cap lead
Choose a lead on the cap and hook one tesla primary side to it
Place a spark gap lead(nail) tothe primary's other side
Finish by wireing a nail to the non tesla primary side of the cap
And space the gap til it fires
Seems hard to follow if you still have trouble I will make a video, just let me know.
