3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Microwave Turntable Guide--make a replacement
Someone donated an old microwave to our church office. The plastic frame of the turntable guide became distorted after many years. The white rollers continually came off of the ends of their axles. That caused the turntable to stop and to tilt.
We did not want to spend around $20 for a new turntable guide (even if we could find one the size we would need), plus still more dollars for shipping and handling.
Step 1Measure Your Microwave's Bottom
Measure Your Microwave\
You will need to know the outer diameter of the circle scribed by the rollers as the turntable revolves. In this Instructable I usually refer to the plastic rollers as white. Here one is shown in cross section as pale yellow for the sake of distinguishing the roller from other items in the graphic. The bottom of the microwave has rises and falls stamped into the metal, as you see here. When you decide on inner and outer diameters for the ring that will hold the plastic rollers, you will need to evaluate how much space you have so the ring does not bind unduly between the microwave bottom and the glass turntable. A cross section of the fiberboard ring is shown here in a copper color. The turntable drive is at the center of the fiberboard ring and the turntable. It is not always easy to get a clear view for measuring when peering into the microwave.
5 comments
Oct 24, 2008. 7:39 AMkillerjackalope says:
I still haven't got round to replacing out microwaves turntable, I just balance plates on the gear, which is good for anything other than zapping a dinner that involves many things... I'd test that theory in an old microwave before using it, something doesn't seem to add up there, not sure why but it just seems a bit odd, a couple of motor brushes grounded to the frame touching the metal piece would keep contact well enough and wouldn't be high maintenance at such low RPMs.
Oct 26, 2008. 4:00 AMLftndbt says:
Hmmm, seems to be a common problem... I also enjoy trying to balance my meals before nuking 'em. I was thinking along the lines of just epoxying the glass plate to the gear mech. But I have held back on that idea as I am thinking there is most probably a reason you shouldn't put epoxy in a microwave... Well it's may be fine, but still.
Oct 24, 2008. 8:10 AMkillerjackalope says:
If there's a microwave being replaced any time soon I'm happy to try it out, I want my mother to give up on her stainless one, it looks good and is missing the plate but the second wall of steel would make me more comfortable with experimentations, also it's 900W so it'd have good components. We did have two industrial microwaves come with a house that used to be a B&B, sadly they were skipped, you could put anything in them and they'd continue on working, I once managed to get the superheated water experiment to work with one, it's mad...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
476
Author:Phil B
I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my...
more »
