3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Mil-Spec PEZ Dispenser
Build a flashing, remote controlled electro-pneumatic PEZ Dispenser with semi-auto and full-auto capability.
What you need:
1. Sense of humor
2. 1/2 a brain
3. Get fired from your job for having all of the above.
Step 1Parts List
Parts List
What I used:
1. Pneumatic cylinders (1-single acting spring return, 1-double acting)
2. MAC solenoid valves (3 way, 5 way)
3. airbrush propellant
4. 2 transistor (FETs)
5. 38khz IR detector
6. TV remote control
7. Controller board (Basic Stamp or Arduino)
8. LED
9. lever switch
Cylinders are from Clippard.
15 comments
Aug 18, 2008. 4:45 PMb2gills says:
Now you need to do an instructable on how to modify a semi-automatic pez dispenser, into a full-automatic pez dispenser.
Feb 8, 2008. 1:16 PMDr.Paj says:
You need to get this thing fully automatic and to have a larger capacity, say...400 PEZ or so. So you could try to build a spring loaded cartridge... kind of like an Uzi or AK.
Jan 7, 2009. 10:16 PMmettaurlover says:
i'd modify one of those huge Darth Vader giant pez dispensers to have a slot so the head doesn't have to come up , a spring loaded firing mechanism to fire them fast and HARD, and a motion sensor to tell it to fire, probably mounted inside the head. TEH ULTIMAT CANDY-BASED WARFARE DEVICE!!!!!
Jan 10, 2009. 8:16 AMrc jedi says:
or meds that go into the other end of your body. just sit on the "dispenser" and boom! you are medicated!
Dec 5, 2007. 5:17 PMrazor1000 says:
Do you have any sources for "beginning pneumatics"? I've been looking around, but I haven't found anything that explains what all those things you mention about the cylinders mean (like single-acting). I'd really like to try some of it out, but it's just hard to get started! (Fantastic project btw)
Jan 2, 2008. 10:51 PMWyle_E says:
A 'single-acting' cylinder can push in one direction, and needs an external force (such as a spring) to return the piston to the 'ready' position. A 'double-acting' cylinder has air ports at both ends and a seal around the piston rod, so that it can push either way. Look at the 'Pneumatics' topics here: /www.mekanizmalar.com/index.shtml
Dec 3, 2007. 12:10 PMjongscx says:
...Wow...
Dec 3, 2007. 7:42 AMlaernmoer says:
A mil-spec TV remote? you got docs on that? just kidding, this is the most perfect waste of time I've seen on this site. (-: Props to you.
Dec 2, 2007. 4:48 PMGorillazMiko says:
niceeeeeeee
Dec 2, 2007. 2:45 PMVertigo666 says:
Nice. Now you need someone on the recieving end with their mouth open.
Dec 2, 2007. 11:16 AMDorkfish92 says:
Wow! That's the coolest PEZ ever! Nice thinking!
Dec 2, 2007. 11:00 AMzjharva says:
HOLY CRAP!! that is awesome :p wooooooooooooot!
Dec 2, 2007. 10:54 AM!Andrew_Modder! says:
LOL
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:el_roboto_loco
