Mild Steel-robo
Introduction: Mild Steel-robo
This robo is designed for the robo war. It's structure is made up of mild steel totally metallic body.....
Ist waight is around 25 kg. It has one wapon called rotation drum..... Here we use momentum..... By making drum waight around 5kg nd giving it high velocity by high torque dc motor, which positively destroy the otger robo during war by transferring momentum during collision ?.
The controls are totally wireless, here we use fsi6 transmitter and fsct6b reciver...
We havw also use apm. 2.8 as a controle bord
Step 1: Selection of Components
Getting all required components as mentioned in pdf...
Check here working and calibrations..
Step 2: Programming Part
Calibration and programming of apm and Esc.
Step 3: Caches - Body Base of Robot
Creating basic structure of Robot by cutting metal sheet.
Then joining by welding the metal in the required shape
After welding removal of slag and granding.
Step 4: Electronic Setup - Soldering
Soldering the bullet connecter to motor
And xt60 to battery input plug and motors connectors etc.
Step 5: Creating Rotating Drum As Wapon for Robo War
We have waded a metallic strip at the two adjacent side of circuit cylindrical metallic pipe and hold it with metal Base which have ball baring at the two adjacent ends of cylinder which is fixed on solid metal axis. At one end we have also fixed a metallic gyre which is connected to motor through timing chain...
Step 6: Install the Moto and Othere Relatives
Motors are fixed to there respective position as shown in pictures one is for drum and other is for motion of robo..... Apm, esc, battry, power module, gps, all the components are fixed to there position as you can see in the picture
Step 7: Final Panting Finishing....
Painting is done by removing or covering electronic components. After drying the components or fixed
Checking for any defects is important part...... Like wiring, connection.... Etc
Step 8: Testing and Checking.
The last step is to check the working of robo.
This is my first instructables post. Please support me as a member.
Fore more check my YouTube channel
    • Paper Contest 2018
      Paper Contest 2018
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    Thanks for sharing :)
