While looking around for container garden solutions, we came across the not so affordable UK "air-pot" design that encourages better root growth than traditional container gardening. Intrigued and still wanting an affordable solution, milk crates came to mind with some sort of liner. Milk Crates seem to be laying around all over the place until you actually start searching for them. Fortunately, we found an inside connection to "borrow" them from for the growing season.
To stay true to the "air-pot" concept we needed the liner to be breathable; landscaping fabric was the obvious choice. A $10 roll of landscaping fabric commonly comes in a 3' x 50' roll which is enough to make 24 milk crate liners. How's that for affordable?
Remove these ads by
Signing UpStep 1Required Tools and Materials
24 - milk crates (washed and sanitized)
1 - roll 50' x 3' landscape fabric
1 - spool all-purpose polyester thread
Tools:
Scissors
Measuring Device - Tape / Ruler
Sewing Machine or (Needle, Thread and Patience)
Suggestion:
Give extra liners to friends so they can grow on their balconies and then share the bounty!
How do you catch water, though? The set up looked great, but, ease of watering is key!
Thanks!
Cut up an old hose, attach a mail end to each and screw into the adapters. Then find a bucket you can lift above the crates for watering. Cut some holes into the bucket to insert the other end of the hose into (toward the bottom obviously), seal with silicone and fill with water.
When you have the bucket above the planters, gravity should take care of it. You may need to refill the bucket but the drip diffusers take a while, so you may want to leave them off and just let the water flow.
We used to do something similar with a large funnel and rubber tubing to water the Christmas tree. Left the end of the tube in the water reservoir and hid the dry funnel behind a big gift box.
I also learned that where space is an issue, you can plant like others would never think of. I've planted root crops (beets and carrots) under my pepper plants. I've planted Corn to shade my delicate herbs. Corn only grows just so high in a container- experiment with it.
This is great though-I never thought of landscape fabric. I've used 5 gal buckets with holes near the bottom. I've used empty cans and bottles to keep the weight down and promote drainage too. miracle grow was also a big boost as well.
Happy Harvest!
You might consider lining your crates with black plastic trash bags (poke holes for drainage) or recycle some empty potting soil bags, etc. instead of the landscape fabric. They won't look as nice but will function better for water retention.
I have found that a much less work intensive container garden is the "Earth box" type of container. You can easily make them yourself out of plastic boxes, buckets, etc. There are plans for them here on Instructables and all over the web. These type of containers hold the water well, are easy to maintain and easy to reuse. Good Instructable tho.
I love the modular design of this. Even though we have a yard where a garden can go in the ground, there might be some real advantages to this. A few could be set on a cart of some sort and moved around to get better sunlight, and they can be put on a frame or table where it would eliminate all the stoop labor.
Many eons ago my dad used to shred newspaper in his chipper/shredder and then till it into the soil to enrich it. Hmm, maybe I should try his trick in my garden, or in my compost bin.
Also, anyone who might want to put a lot of dirt and water on a balcony should consider whether the balcony can take the added weight. Since yours has no door, it may be that the structure wasn't planned to bear any load. Construction codes are a lot more strict in some parts of the world than in others.
The building is 100+ year old greystone hopefully this porch is over engineered since it is made out of stone and weighs probably a 1/2 ton already. So a few more stationary pounds shouldn't matter...
This would be cool combined with the "upside down" planting idea.
I look forward to seeing more air-pot inspiration...
