But can they be elevated, aesthetically and practically? I've tried before, and came up with a quick wall-mounted solution. Recently, I came into a trove of crates while demo-ing out an old building at work. I wanted to come up with a piece of free-standing milk crate furniture that didn't look cheap.
The Milk Crate Credenza is light, strong, and handsome enough, reveling in rugged simplicity. A beautiful wood top contrasts with the cold, clean plastic while tying the crates together structurally. Made with little more than a drill and zip-ties, it took about two hours to put together.
Milk crates are not free for the taking from behind stores. Those stores, or the dairy companies, pay for the crates, and when they go missing, it hits the bottom line. Be respectful. Ask. Shop owners may part with a few lightly damaged ones. New crates are available all over the internet, at dozens of sites. Thrift stores, record shops, and dumpsters are other solid sources. If it is not directly behind an establishment that sells or uses milk, then it is probably abandoned to the world and available to take. Check out Milkcrate Digest for more info on legally acquiring crates.
And, if you folks enjoy the piece, please throw a vote my way in the Furniture Contest! Furniture is all I post here at 'structables, and I'd love a little love to keep 'em coming!
You will need these materials:
3-5 milk crates
1 piece of 1" x 12" material, about 4' long, or plywood, etc.
Zip-ties
Wood finish of your choice
You will need these tools:
Angle grinder, Dremel, or hacksaw
Circular saw or table saw
Drill
Needle-nose pliers
Wire nippers or scissors
Tape measure
Sandpaper
Rags
Remove these ads by
Signing UpStep 1: Toppin'
Start with a 1" x 12", a piece of plywood, or several smaller planks that can be knit together. Use a circular saw or table saw to cut it to 11" wide, which is the height of a crate. Cut a few small strips (approx. 3/4" x 3/4" x 10"), and screw and glue them to the bottom of the top piece of wood, spaced to land in the center of each crate (approx. 13" on center). Cut it to length. If using less than four crates, adjust accordingly.
Drill three 1/4" horizontal holes through each strip, about 2" in from each end and in the center. These will serve as mounting holes for threading through the zip-ties. The main purpose of these strips is to provide a blind fastening system for the zip-ties -- a way to attached to the top to the crates without the zip-ties having to puncture the top. The top could be "sewn" directly to the crates by drilling holes through it, but then the zip-ties show. Visually, the spacer strips also create a reveal between the crates and the top, a nice shadow line that articulates each piece.
The strips could also be used to attach several narrower boards together, to create a top out of smaller scraps.
Sand and apply a finish of your choice. I used a blend of boiled linseed oil, polyurethane, and thinner, followed with paste wax.
Visit Our Store »
Go Pro Today »
Not only this is a brilliant idea but I also think it has a lot of humor in it !!!…
Thank you for sharing !!!…
