Milkcrate Composter (vertically stacked) by a_abbond
How to make a vertically stacked composter using milkcrates.
This instructable is based on Terracotta home composter by artworker
http://www.instructables.com/id/Terracotta-home-composter/
and the creators of the terracotta composter, Daily Dump (http://www.dailydump.org/ )
When I saw the terracotta composter, I though it was the most brilliant composter I have ever seen.  It was also absolutely beautiful.  I saw some problems however.  First, the price for terracotta pots this size is expensive (my favorite budget is 0$, so that didn't quite work...).  Second, the amount of work to find the pots that will stack well, make the holes without breaking the pots, the fragility of terracotta, and the weight of it was against this lovely project.
Then I though of the perfect substitute, a milkcrate!  It stacks perfectly, has plently of air circulation, is sturdy, has handles to lift them easily, light weight, low cost.  All you needed is 3 milkcrates, mesh/screen, newspaper, a lid, and a base if it's not resting on the earth directly.
The only down is the aesthetic of it, the terracotta pots are so beautiful.  But the milkcrates has their own charm, especially in my urban surrounded garden.
So here's my milkcrate composter!
Step 1: You will need
materials needed:
-3 milkcrates
-plastic or metal mesh/screen, or weed barrier fabric
-scissors
-hot glue gun
-wood
-saw
-drill
-screws (preferably rust proof)
-old drawer handles
-varnish
-newspaper
-and organic waste to start your compost
To make this project, all the material I used were either found, reused, or I had it already at home, so the total budget was a wonderful 0$!
Step 2: Prepare your milkcrates
Choose your milkcrates
You could decorate them using paint, but you could also leave them the color they are, especially if you have various bright colors.
A note on composting however: black will generate more heat that will help the compost and speed things up.  But it is not as pretty...
I decided to use two black ones and one red to add color
Clean them with a rag.
Cut pieces of your screen/mesh or weed barrier fabric and hot glue gun them inside the milkcrates to cover the side holes.  This will keep your compost inside and prevent pests to go in, but air and water to circulate.  I had leftover of weed barrier fabric that I used for my square foot garden, so I used that, but you could salvage some mosquito net from a tent or an old window that ended up in the trash.
Step 3: Lid and base
Use wood (or other material) to create a lid and a base (to protect your floor if your composter is not resting directly on the ground)
To make this lid, I used old wood from an IKEA bed frame, and old drawer handles that I salvaged from my neighborhood trash.  My composter will be resting on the earth directly, so I do not need a base.  I glued and used screws to hold the wood planks together to form the lid, drilled holes to attach the handles, and varnished it to protect it.
Step 4: Assemble your composter
Choose the spot where your composter will go.
Lay 2 layers of newspaper at the bottom of your milkcrates to stop the compost from falling through, stack them (on the base if you have one), and put the lid on.  Your composter is now ready!
Step 5: Start composting
You are now ready to start composting!
Good luck and have fun!
here are the steps and image with instructions taken from the Terracotta home composter by artworker ( http://www.instructables.com/id/Terracotta-home-composter/ ) and created by Daily Dump ( http://www.dailydump.org/ ) on how to use your composter (Pot A would be the top Milkcrate, Pot B the middle Milkcrate, and Pot C the bottom Milkcrate)
Composter Process:
Start adding the kitchen waste to the composter (Pot A)
When the Pot A is 3/4 full, switch the Pots A and B. And start adding the materials in Pot B which is now at the top.
When the Pot B gets filled 3/4 the ingredients in Pot A has shrunken.
You can again switch the Pots A and B
When the middle tear pot gets almost filled 3/4, empty the middle tear Pot to Pot C
And start the process all over again.
The final contents of Pot C starts shrinking and thus more materials can be added from the middle tear Pot to Pot C.
When Pot C gets filled 3/4 empty the pot before starting to fill the Pot C again.
At this point the contents of Pot C has decomposed completely.
Sieve the contents of Pot C and you get perfectly good non-smelling manure (compost).
The larger pieces that are left after sieving can be added to the Pot at the top for further decomposing.
Keep the compost little damp by sprinkling water in the upper Pot occasionally.
The whole process takes around 90 days.
You can find much more instructions on the Daily Dump website on how to compost and troubleshooting that I recommend reading.  http://www.dailydump.org/
Gregbot says: Feb 2, 2013. 6:56 AM
excellent!
prismcat says: Aug 8, 2012. 2:43 PM
Brilliant! This totally solves my problem...I've been after my husband for years to make a "proper" compost bin. We've always just piled the vegetable matter in a certain spot and let nature do it's thing. Then he plants something in that spot the next year and starts a new pile somewhere else. While his method actually does work for us here in the hot and humid Southern US, only one spot each year gets compost With this plan, I can actually make a few of these myself and put it where ever I want, yay!!! Thank You!
porpor1234 says: Jul 9, 2012. 2:06 PM
Has anyone discovered whether the bottom crate has really turned into compost by the time it runs out of space or does it need to be shifted into another place to complete composting? The daily dump instructions also say to keep adding accelerator every 15 days to the hold-it pot. is this necessary? Do the milk crates compost better than the terracotta pots and don't leave the contents of pot c incompletely done? I would like to try this as I've had various plastic compost bins in my yard that don't seem to work very well - it takes a long time to get the contents to decompose fully.
a_abbond (author) says: Jul 16, 2012. 6:37 AM
In my experience, the compost at the bottom was ready before I filled the other ones. We are two and I use it to compost kitchen food scraps. the only thing you have to do is go through the earth and remove the big pieces that did not decompose in one shot, such as big corn cobs pieces or avocado seeds. I just dump them back in the first bin. I don't use hold it pots since I use my compost before that. I would say the process is taking longer that regular compost because you don't have the heat of a large pile, and since I live in Canada, it stops completely once it's too cold. And I haven't used the terracotta either because of freezing that would make the pots break.
If you want to speed the process, cut your compost material in small pieces of no more than 1 inch, add a handful of dried material (leaves, dry grass) for a handful of kitchen scraps, mix it well often, and check so you have the best humidity (not soggy, but not dry)
CatTrampoline says: Jul 21, 2011. 9:51 AM
Genuis! My old garden on 1/3 acre had giant open piles in bins made from pallets, but the curren tiny urban yard needs something scaled-down that I can hide behind a tool shed. The holes in the crates will be perfect for air circulation and draining excess water during the monsoon season. Two green thumbs up!
LosingAmy says: Dec 29, 2010. 3:10 PM
First off, let me say how great this instructable is. Perfect for a small space and/or small budget. I'm going to be making two of these myself and it'll run me about $12 since I don't have the weed barrier fabric on hand. I figure I'd need one for myself and one for my husband since we tend to produce a good bit of vegetable waste.
I'm personally probably going to use a little more of the fabric to line the bottom of the bed, or omit this step. I only say this because some holes on the bottom of milk crates can be small, and if so, who cares if that little bit of compost from Bin A goes to Bin B. It's all getting mixed up anyway. Also, I've been reading about some of the colored inks in newspaper can contain metals. Since I'm using my compost for vegetable gardening, I rather not take this chance. So if the holes are big, I'll line with a little extra of the weed barrier.
a_abbond (author) says: Dec 29, 2010. 8:09 PM
Yes, good point about the newspaper! You have to be careful that it is made with vegetable inks. Good luck with your composters :)
dmccomb says: Mar 12, 2011. 1:26 PM
The concern about metals in colored inks is outdated, especially in newspapers. Newsprint ink is the cheapest possible and has to be recyclable, which means it is made from soy. Heavy metal inks are expensive! (And dangerous, which is another reason they don't use them any more.) These days, the only inks you have to worry about are the ones which are fluorescent or metallic - they're usually found in advertising supplements or packaging materials, not the general news sections. Anything else is compostable, even on glossy papers.
blckbuster says: Jul 12, 2010. 5:52 PM
how bad does something like this stink? could one get away with using it in backyard of a dense city?
a_abbond (author) says: Jul 13, 2010. 4:16 PM
This compost method was develloped to be used in Indian cities as an alternative to composting for dense city dweller. They can be used on balconies. If you maintain the right amount of dryness/moisture, the compost should not smell. A compost that is too wet will stink, you have to add dry stuff - leaves, shredded paper, sawdust -, a compost that is too dry will take longer to decompose, so to be on the safe side, keep it more dry then wet.
a_abbond (author) says: Jul 17, 2010. 8:31 AM
Some more details on composting that I didn't add earlier. A compost that has plenty of air will not smell. A compost that has not enough air (for example if it is soggy and all packed together - hence the problem with wetness) will decompose, but in a process that will generate bad smells. This is why it is important to mix your compost often to allow the pile to be well aerated and to check the moisture level.
artworker says: Jul 11, 2010. 10:14 PM
Brilliant! Your Garden is very beautiful. 5*
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
