Millefiori Beads from Polymer Clay
Millefiori is Italian for "Thousand Flowers."  Originally a technique used for making decorative glass works, a similar process can be used to make designs in polymer clays, such as Fimo and Sculpey.  These materials are perfect for beads, earrings and other jewelry, as well as for adorning pretty much any object that can be put through the oven at 265 degrees.
Using the Millefiori technique, a long tube of polymer clay is created.  Each slice of this tube is a copy of the original design.  In keeping with the Thousand Flowers translation, I will show you how to make one of the most basic Millefiori designs, a flower pattern.
***UPDATE 5/4/10:  If you make this project, post some pictures in the comments below.  I'll send you a patch!***
Step 1Choose your clay and colors
I like Fimo Classic.  A lot of people like Sculpey (which is much easier to find at brick and mortar stores, and usually cheaper) or Fimo Soft, as these clays are much easier to work with in the short term.  Fimo classic really has to be worked a lot with your hands to get it to a malleable state.  However, I find that the softer clays, especially Sculpey, smear when you cut them--even after being refrigerated.  Also, the more vibrant colors have a tendancy to rub off onto your hands and contaminate the paler shades.  This is still a problem with Fimo Classic, but much less so.  I also think the colors are better overall with Fimo, even Fimo Soft, but that's just a subjective opinion.
A good craft store will have a lot of different shades to choose from.  I prefer to buy primary shades and lots of black and white and mix my own.  That provides a smoother color gradient and greater control over the end result.  Also, it's way cheaper that way, and mixing the colors gets the clay worked to a usable consistency.
For this flower, I've chosen a green center with blue petals on a white background.  It's a good idea to pick a high-contrast background or it will be hard to see the boundaries of the petals.
40 comments
May 9, 2011. 10:45 PMMrballeng says:
I've always wondered how this was done. Thanks for taking the time to put this together.
Feb 8, 2011. 2:16 AMKJS says:
HI, really great 'ible, a bit long, but easy to understand :)
I will definetly try this sometime, when I find the clay, and the time.
The only thing I'm not sure about is: How do you know how much to make of each color, so you don't end up having way to much of one color/shade and not enough of another?
Do you just do it by eyemeasure?
But again, really great 'ible and great beads :D
Feb 9, 2011. 9:08 AMKJS says:
Thanks for the fast answer and the tips :)
I'll be sure to post pics if and when I get to trying this out!
Aug 26, 2010. 8:10 AMlidzy says:
I was always fascinated by this technique, and wondered how it was done; guess i'll be buying my polyclay beads ready-made..this is great, but a lot of steps..thanks for showing me just what polyclay beadmakers go through! I have a bit more appreciation now...
Apr 13, 2010. 3:42 AMPurple-tiger says:
 Awesome instructable... I will definitely try this. Is there any one clay that is better than another for making canes? I am really new to this and mine don't seem to be turning out the way I would like.
Thanks in advance ^_^
Mar 15, 2010. 9:03 AMLettucehead says:
 I love working with polymer clay i will try this! Thanks! :)
Feb 21, 2010. 2:37 PMJ@50n says:
im in the process of blending right now :)
Feb 22, 2010. 1:55 PMJ@50n says:
 first 2 - "bead" mine got kind of dis functioned.
last 2 - "Beads" put in a strip and rolled out to make a book mark.
Feb 22, 2010. 4:19 PMJ@50n says:
 do you have any tips?
Feb 22, 2010. 3:44 PMJ@50n says:
 yes. i saw this, went to Michaels (craft store) bought $30.00 of polymer clay and got to work... i have also made an incense burner using this method but with swirls not flowers.
Dec 31, 2009. 2:36 PMJoesgrrrl says:
These look fantastic, as always! What did you do w/ them??
Jan 2, 2010. 12:56 PMbeadydani says:
Oh there is a market,  me, I will buy from you instantly. I have tried making clay beads but it just comes out wrong besides I really don't have the time anymore. I prefer designing jewelry to making beads, I see it as taking too much of my time which could be spent making necklaces, accessories, etc.
Lovely tut and thanks for sharing
Jan 7, 2010. 4:42 AMbeadydani says:
Try Etsy, Ebay, MISI and other 'craft' online shops, just do an online search. The sky is your limit.
Dec 31, 2009. 4:13 PMJoesgrrrl says:
Seeing the pic of your old one's sure brought back memories. I was always impressed at the amount of detail you got in them.
Dec 14, 2009. 8:45 AMddenis99 says:
thanks man! great 'ible  - i'll be wanting to try this for a guitar fret board inlay.. I'll need to roll it down pretty small though, about a quarter inch.
Dec 8, 2009. 4:55 PMloveblackwolf says:
This was an awesome video/ tutorial combo thank you for putting it together and sharing.  I know nothing about Polymer Clay and would love to get the benefit of your experience.  From the video it looks like you've been sculpting with it for a long time.  How do you chose a design and then  figure out what shapes you are going to make an how they'll fit together?
Dec 8, 2009. 6:19 PMloveblackwolf says:
I've always been curious how people do mushroom shapes with inlaid characters, or flower designs.
Dec 8, 2009. 4:46 AMblacjack1 says:
oh man this is awesome, will make great christmas tree decorations, also isnt this how they make patterned rock candy?
Dec 7, 2009. 11:36 PMcokecola says:
Why didn't you just make a skinner blend for the green and blue in this cane?
Dec 7, 2009. 6:19 PMkissiltur says:
This is a great technique that is used for making seaside rock in Britain too.
How do you avoid distortions when cutting the finished cylinder? Is it just a matter of having a sharp enough blade?
Dec 7, 2009. 10:33 PMcraig3 says:
If you cut it with a blade, when its still very fresh from the oven, that gives the cleanest cut with no distortion or flaking
Dec 7, 2009. 10:04 PMkissiltur says:
It's a hard candy iften sold at British seaside resorts, archetypally at Blackpool but when I were a lad you found it everywhere you went.
Here's a page showing how the letters are made, and the process is very reminiscent of the millefiori technique:
http://www.attractionsblackpool.co.uk/Blackpool_Rock.htm
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
287
Author:depotdevoid(depotdevoid on Facebook!)
Like me on Facebook, my poor, fragile ego needs a boost! I post updates about my current projects, and the occasional sneak peak at upcoming instructables! ...
more »
