Minecraft House
446
Posted in PlayMinecraft
Introduction: Minecraft House
First go out and explore for some flat ground and find some flat ground and get ready to build.
Step 1:
Then you dig the a layer of dirt out of the ground by holding holding down the position with your thumb on your phone. Then you use a sturdy material from your inventory such as wood to fill up where you dug from step 2.
Step 2:
Then you build four columns to hold up the house by going to each corner and tapping with your thumb once until it had stacked up at least 4 times. Then repeat in each corner
Step 3:
Then fill in the space between the columns to be your walls by tapping each block on the columns until it reaches the other side .
Step 4:
Then you put a door so you can enter the house by digging out 2 blocks and going to the inventory and picking tapping on the door and then filling up the whole with the door.
Step 5:
you dig out some 4 blocks and fill them with glass. Then you have some windows in to get some light in your house.
Step 6:
Repeat step 5 on the other side of the house.
Step 7:
Then you fill in the roof by using material you have been using to fill in be using the same process as step 3.
Step 8:
You put some torches in as a light source during the long nights. Then hang them on the wall by using them and tapping them on the wall.
Step 9:
Add a bed so u can rest during the night to make time go faster.
Step 10:
Also you should add a painting to look fancy and for gest.(hint hint)
Step 11:
Add a rug for the hard wooden floor.
Step 12:
Then you might want to add a tree and you are done with an awesome house.
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    Cool house!
