Minecraft Machine Gun
Published
Introduction: Minecraft Machine Gun
Hey guys, and today, I'll be showing you how to build my own model of a dual dispenser machine gun
Step 1: Make Sure You Have the Right Materials
I'm not saying how many because I like doing this in creative mode, so here goes:
Block Of Quartz
Repeaters
Redstone Dust
Button
Sticky Piston
2 Dispensers
1 lever (for redstone lamp)
1 Redstone lamp (optional)
Step 2: Step 2: Build the Frame
you will need a 3 wide, 8 long platform for this, and you need to remove the blocks as shown in the picture
Step 3: Redstone Time
Put a piston in the missing block space closest to the left end of the picture and put a block of quartz on top. Then, put a repeater in front and behind it, with redstone behind the behind repeater as shown in next picture
Step 4: The Infinite Clock
Place two repeaters in the middle facing exactly opposite to each other in a clockwise/counter-clockwise position, then put redstone on each ends of the 2 repeaters as shown in picture
P.S. the repeaters have to be right beside each other
Step 5: Step 5: Dispensers
place redstone on the two blocks sticking outwards from the clock, but do not put them on the ends. At the ends, place dispensers and fill up with as many arrows/flame charges/TNT as possible
Step 6: The Ignition
go to the very end where the piston is and place a block on top of the redstone with a button facing away from the machine gun
Step 7: The Optional
Now notice that this is optional if you want it, but this is a safety switch.
Put blocks all around the dispensers and put a lever in between both of them. Then put a redstone lamp above the lever. What this does is the lever deactivates the dispensers from firing, and the redstone lamp is there to let you know if the safety is on. In other words, if the lamp is on, the safety is on, if the lamp is off, the safety is off.
Step 8: The End
I hope you enjoyed this, and I hope your machine gun works. There are pictures of the finished product below after the other 2.
    • Stick It! Contest
      Stick It! Contest
    • Woodworking Contest
      Woodworking Contest
    4 Comments
    and to add on, it is the fastest machine gun that uses only 2 dispensers to this date, but if you wire it right, you could shoot about 10 of them with a single press of a button and it still be kind of compact
    yeah sorry, that's my first instructable, but it shoots really fast if you build it right
