Minecraft PE IOS Modding
Introduction: Minecraft PE IOS Modding
This is a tutorial on making your own "mods" for the mobile version of minecraft for apple devices.
Jailbroken iDevice
Theos (Good tutorial here.)
IDA Demo (Link)
Mobile Terminal (Search on Cydia)
Decrypted Version of MC:PE (Note: I do not encourage piracy, DO NOT distribute the file you get from this process, if you do I am not responsible.)
Clutch (Link) (.deb) (DO NOT USE FOR PIRACY)
WinSCP or CyberDuck
IP Address of your iDevice
This Program (Win Only); I have a template downloadable for Mac and Linux in a later step.
It would help to have a bit technological skill.
Basic C/C++ Knowledge
If you have any problems leave a comment and I will try to help.
Step 1: Decrypting the Binary
Open Mobile Terminal
After opening Mobile Terminal enter the following commands:
su (password is alpine (Unless you changed it))
Clutch minecraftpe (must be Clutch not clutch)
Exit Mobile Terminal and go to IPA Installer
Navigate to /var/mobile/documents/cracked/
Press on Minecraft PE
Wait for it to install and then go to the next step.
Step 2: Copy Binary to Computer
Open WinSCP or CyberDuck.
If you have dropbox enabled in iFile, you can copy the binary to that, it's how I transfer files back and forth without SFTP.
I will be using WinSCP.
Host name: Your devices ip address (Found by going to Settings>Wi-Fi>i button by your SSID
User name: root
Password: alpine (Unless you changed it)
Go to /var/mobile/Applications (iOS 1-7) or /var/mobile/Containers/Bundle/Applications
Open each folder and look for minecraftpe.app; once found go into the folder and copy minecraftpe (no extention) to your computer (If you want enable application names in iFile and either copy the minecraftpe file inside of minecraftpe.app to /var/mobile and then follow these steps)
Mine is at /var/mobile/Applications/3E037D75-819A-4DEE-BC03-C1F5F8FBDE57 but your's will be different.
For an easier time copy the file to your desktop.
Step 3: Open the File in IDA
Open IDA Demo
Press New
Then select minecraftpe from your Desktop or from wherever you put the file.
Press on the drop down box that says MetaPC and then select ARM little-endian and then press Set
Click on ARMv7 then press OK.
Press Yes if it says "Objective-C 2.0 structures have been detected." Press Yes, and then OK.
Wait for it to load some things, for about a minute.
Step 4: Find a Function
Look through the functions on the left and find a (int) or (float) (You can test with a few voids but it could have bad outcomes.)
I am going to use LocalPlayer::causeFallDamage(float)
What we need is __ZN11LocalPlayer15causeFallDamageEf and will look somewhat like your function you chose.
This will be located in about the same place in the image after you click on the function in the side bar.
Highlight and copy that.
Step 5: Making the Mod
Open the program you downloaded: MSHook EZ Writer GUI.
Where is says Symbolic Function paste what you copied.
Then select Int, Float, or Bool depending on the function you chose.
Then put the value you think would work. For fall damage we will use 0 so the player receives no damage.
Press Add, click in the text field that starts as #include then CTRL-A then CTRL-C
Download this file.
Fill in the places where it says "*your return here*" with "int, bool, or float"
Same with function and value.
Function is the symbolic function we copied. (__ZN11LocalPlayer15causeFallDamageEf)
Make a new file named Tweak.xm
Paste the code from the template or program into the file.
Switch back to your device.
Go to mobile terminal.
Do not do su this will break the creation process.
Type $THEOS/bin/nic.pl if that doesn't work then type /var/theos/bin/nic.pl if neither of those work, then reinstall theos.
Type the number that corresponds to device/tweak then enter. (Mine says iphone/tweak)
Fill out all the forums, when it asks for the app bundle identifier type com.mojang.minecraftpe
Then complete the forms.
SFTP back into your device like you did when you copied the binary to your computer.
Go to /var/mobile/yourmodtitle
Copy Tweak.xm from your computer and overwrite the Tweak.xm in the directory.
Return to your iDevice.
Open mobile terminal
Type cd /var/mobile/yourmodtitle
Type make
Type make package install to install the mod for testing.
To do it without installing the mod:
Type make package
make package (install) will put a deb in /var/mobile/yourmodtitle that you can distribute. If you would like I can host your mods on my repo, just email me: repo@addie.us with a link to your deb and I will give you the link to the repo.
Enjoy and please vote!
    • Science of Cooking
      Science of Cooking
    • Paper Contest 2018
      Paper Contest 2018
    • Trash to Treasure
      Trash to Treasure
    Whoa, nicely done!
    Hello! After I typed "make" the mobileterminal "/theos/makefiles/targets/Darwin-arm/iphone.mk.21 : ***first argument to 'word' function must be greater than 0. Stop."
    It seems you don't have a SDK installed. Download a SDK from http://iphone.howett.net/sdks/ if you are on iOS 8 or lower otherwise I'm not sure where a iOS 9 SDK would be Place the downloaded SDK in /opt/theos/sdks and try again.
    Sorry! /var/theos/sdks my bad.
    I followed the direction exactly and it didnt work. no errors, I still get fall damage. any help?
    Sorry for the extremely late reply, when you replaced *Your function here* did you keep the extra stars? Only the stars directly by your function here should be removed. For example *your return here** should be float* or *your function here*** should be __ZN11LocalPlayer15causeFallDamageEf**
