Minecraft Shower
39,027
30
22
Published
Introduction: Minecraft Shower
Due to some comments, I am remaking this instructable, I hope this one is more clear and easier to understand. I have also taken screenshots of the project rather than pictures from my phone. So, here we go.
Step 1: Base
Dig a 4x3 rectangle. Now dig those same dimensions down one more so it looks like the 2-block-deep hole in the picture. Now, using your choice of materials, fill the bottom of the hole. Now, fill the layer above the one you just placed down but leave a hole like in the last picture.
Step 2: Walls
Now, build a wall 5 blocks up on the back portion of the shower (see picture 1). Do the same for the other two walls like in pictures 2 and 3.
Step 3: Roof
Now fill the roof in. Add in two blocks so that there is an indent in the roof that will be used later.
Step 4: The Piston
Punch out a hole on either side of the wall. It should be 3 blocks up from the floor, or one block taller than your character. Now put the piston in the hole and make sure it is facing in.
Step 5: The Water
That indent you created in the last step will be used to place the water
in. Put it up there and watch it flow down. There will be no current due to the hole you created in step 1.
Step 6: Lever
Put the lever right next to the piston. Now you can control the water flow. Simple as that.
Step 7: Door
When you stand back from your project, you will notice that there are 3 blocks left in the opening. Fill in the top block and place a door into the remaining two.
Step 8: Finished Product
Now you have a shower in which you can control the flow to. I hope this is better than it was before and that it is easier to understand. I love hearing from you guys so keep commenting :)
    • Pets Challenge
      Pets Challenge
    • Casting Contest
      Casting Contest
    22 Comments
    I just built this and it flooded my house...Thanks man :(
    Ok.I feel really stupid.When I clicked the lever,the water spread out a little bit and destroyed the lever so I had to delete the water.
    It was still a really cool Minecraft Shower.
    No need to feel stupid, that happened to me a couple times as I was creating the shower design. Should be an easy fix but I haven't played, I mean truly played, Minecraft in a long time and haven't updated it so maybe this design doesn't work anymore. But anyways, I am glad you liked it, thank you for the feedback.
    -NVD
    Okay, here's a suggestion:
    Instead of taking pictures of your screen, press F2 inside Minecraft instead. That will save a screenshot in the .minecraft folder. It will make the pictures turn out a lot nicer!
    I just updated this instructable, if you would like, check it out and see if you like it better now :)
    Of this was made from an inflammable block you could use it as a fancy way of dousing yourself after a swim in lava :L
    All in all nice first 'ible shame about the pics.
    Thank You! I just updated this instructable so if you would like, come check it out and see if you like it better :)
    If it makes you feel any better, mine are A LOT worse than these.
    Quite o.k. , but some of the picture are kinda hard to tell what you just did
    Pretty good, though
    Just edited this instructable, come check it now and see if you like it better. Thank you for your comment, it helped me get into making it better.
