Minecraft: Slime Block Shotgun
Introduction: Minecraft: Slime Block Shotgun
Hello again and welcome back to another Minecraft instructables by COOLCREEPER69! I will be showing you how to make a Slime Block Shotgun that fires 11 TNTs to about 32 blocks far! This is a quite simple and efficient shotgun that all 11 TNTs will fire together at the same time. Let's begin!
You will need:
•24 Slime Blocks
•18 Obsidian
•2 Sticky Piston
•11 Dispensers
•14 Redstone Dusts
•2 Redstone Torches
•1 Button
•At least 11 TNTs
Step 1: Building Shotgun Parts
Firstly, add a sticky piston onto the ground, then 12 slime blocks from the surface of the sticky piston. Next, add a line of 12 obsidian behind the slime blocks. Now add 11 dispenser on the line of obsidian starting form the end. Behind the sticky piston, leave 1 block of space and add an obsidian with a button and a redstone torch placed on it. After that, place an obsidian in a L-shape from the start of the obsidian that was placed behind the slime block, then add another redstone torch on the L-shape obsidian structure, the redstone torch should be deactivated. Add another line of 12 slime blocks starting from the top of the L-shape obsidian structure, then add another sticky piston facing the first slime block placed on the L-shape obsidian structure. Using the remaining obsidian, build a stair like structure to the dispenser from the obsidian with the button and add redstones from the button to the stairs and to the dispensers. (Refer to image given above)
Now that you've finished the parts, let's move on!
Step 2: Inserting Ammo
Now, place at least 1 TNT in each dispenser. Before you start testing the build, DO NOT spam the button or the build will explode! After that, test it by clicking on the obsidian with the button. The activated TNTs should be launched quite far from the shotgun together at the same time.
Thank you, for coming to my instructables! Please share this if you
think it's good and don't forget to follow me for more Minecraft (or other) builds!
Don't forget to enter my YouTube Channel: https://www.youtube.com/user/COOLCREEPER69
  • Trash to Treasure
    Trash to Treasure
  • Paper Contest 2018
    Paper Contest 2018
  • Pocket-Sized Contest
what the fricking heck? Huh? Huh? Did everything right but nooooooooooooooo right mothrr
What are those buildings in the back of the pictures from step 1?
Hi, sorry for the late reply. Have been off for a long time.
Those are the other builds I did in Instructables. You can check them out :D
You reminded me the wonders of Minecraft's TNT usage, such as cannons. :') Cool ible
Nicely done! Shoots like a beauty. I'm gonna subscribe you too!
