Minecraft Simple House
19,711
14
5
Posted
Introduction: Minecraft Simple House
This house can be your very first house . It wont function later , because it has no place for enchantment table or lots of chests . It's made out of wood and hasn't got any fireplace or other decorations (such as tables or furniture or other creative awesome things )
You will need
Oak wood planks (at least 2-3 stacks)
Oak wood stairs (at least a stack )
Oak wood plank slabs (optional)
Fences (optional)
It doesn't matter what material you use , but oak goes best with fences and is more common than any other wood type .
Step 1: Building the Base
It looks better if its higher than the normal ground level .
You can make it in any size , but I made a 11x5 . Using slabs will cost less wood and slabs don't get caught in flames
Then , place the walls . leave some empty space for a better look . place slabs outside the base as "long staircase" and some fences as a support for the roof .
Continue the shape , but don't forget about windows ! they're important to check if there are mobs nearby or not . I recommend windows on all sides . If your window is 1x1 , it doesn't matter if you don't place glass panes as only cave spiders and silverfish (AND arrows AND wither projectiles) can pass . However not placing glass makes a bad look :D
Step 2: Building the Roof
A flat roof might be easy but it looks very ugly . If its night , you can either make a little dirt shelter to survive and continue building , or go inside your house and put doors and windows . However spiders might come in , so be ready .
We use stairs as the roof . there is no attic , the part under the roof is no new level . As I'm in creative , I have the fly option . But in survival , you must make "nerd poles" (look down , jump , place a block , repeat) and get up .
You must place a block , then place stairs on it , then remove the block . You can keep placing blocks OR place the next stair on the side of the previous stair . Be careful about the directions so it's placed straight .
After all , it should look like the picture .
Step 3: Others
Then add glass panes as window . If you built this house in the nether (which is really bad because its flammable ,)
you must put glass BLOCKS so ghasts don't blow it up . However they can blow the house , so the window wouldn't matter .
You can make an attic by simply adding a flat roof which would be the attic's floor .
You can make a big storage underground and connect it to the house with ladders , same with a nice enchant room .
Thanks for reading .
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    4 Comments
    Whats in the background! of your photo
    hey can you show how you made the bottom of the house in greater detail?
