Introduction: Minecraft Time Machine!!!
Picture of Minecraft Time Machine!!!
Have you ever wanted to be a time traveler in Minecraft, but known it was impossible? Well, now you can!
Step 1: Get a Command Block
Picture of Get a Command Block
Type /give @p command_block and press enter. A command block will appear in your inventory!
Step 2: Make It Do Something
Picture of Make It Do Something
Right-click the Command Block and type time add 20000 and click done. You could also type time subtract 20000, but remember, you can't have both at once. It will only work if you have one or the other.
Step 3: Make It Look Cool
Picture of Make It Look Cool
Place 4 blocks of your choice (I used obsidian) around the command block, as shown. Place 1 stair block on one of the blocks (not the command block) and place a blank sign on both sides to make a chair. Place a 2-block high tower on the side opposite of the chair. Place an item frame with a clock in it on the top block of your tower. Place a carpet of your choice on the command block, and make sure to sneak when you do this or it won't work. Finally, place a power source (button, lever, etc.) on one of the 2 remaining blocks and you're done!
Step 4: Have Fun!
Picture of Have Fun!
Use your time machine to travel through time!!! As you can see, it really works! Have fun!!! I'm in the First Time Author contest, so vote for me!PEACE OUT!!!
JavaProgrammer (author)2015-09-02
Cool instructable, welcome to the community, and good luck in the contest!
now if only Minecraft would modify tohe world to the way it was previously when you went back in time.
RMP2003 (author)JavaProgrammer2015-09-03
I fully agree. And thanks!
TrevorG52 (author)RMP20032018-01-14
on demo
You could create a series of commands to place blocks... but that's a lot of effort xD
Minecrafter4435 (author)2016-02-19
What command do you put in the command block? and do you need mods?
RMP2003 (author)2015-09-10
I've actually used this to build the TARDIS a few times. I'm considering doing that next!
amberrayh (author)2015-09-02
This is cool. Does it really work? The only thing that says the time are your screen shots. Good luck in the contest!
RMP2003 (author)amberrayh2015-09-03
Yes, yes it does! And thank you!
About This Instructable
13,337views
17favorites
License:
More by RMP2003:Minecraft Fireworks!Minecraft time machine!!!
Add instructable to:
