My name is Mic
Sorry for my English (:
My purpose a Very Small Bot
A little easier to build for Robot can we have patience and a good magnifyingglasses,
Its name: Roule_Robot
His nikename: RR
Curb Weight: 14gr
Dimensions: 39 x 22 mm
the necessary components:
An ATtiny13 SOIC
2 micro motor 3 volts 6mm length 12mm diameter (there are on ebay)
2 PNP transistors smd 600mA
22µF tantalum capacitor smd 1
Resistance 2 smd 6.8 K
2 10K smd resistor
1 red LED smd
An IR LED 2mm CQY37N
An IR sensor IS471F
A male strip SIL
A LiPo battery 3.7 Volts 70 mA
wheels made with the box tops tablets
they are stuck with glue or araldite cyanolite, just put in on the end of the shaft and be
careful it does not flow into the engine if not done for
motors and the battery are replacement parts for Mini Helicopter
The PCB is double sided but I avoided this by routing method on the component side with
wire phone
must also clean the PCB with acetone once finished welds.
Note: the programming is done directly in BASCOM ISP
we must remove the jumper SW1 (if not the ship is not recognized randomly)
and recover from the operation of the IR sensor
programming:
demo version of BASCOM April
the program is simple and there is room in the flash memory there
is also theATtiny13 and two free ports
and we can add lights for example.
The ZIP file contains all the pcb made ââwith Kicad and 3D components made ââwith Wings3D
images of 3D PCB are kicad screenshot of 3D rendering
Kicad wings3d and are both freewares
Remove these ads by
Signing UpStep 1: Tools
A tweezers with small beaks
A keyless tweezers
A soldering iron very fine tip
A UV PCB exposure machine
perchloride for PCB burning
An epoxy plate presensitized 16/10
transparent to an inkjet printer or better laser printer
1 decimetre
1 metal saw
welding of: 1 mm max
Kicad software for printing the transparent
Visit Our Store »
Go Pro Today »
Thanks,
Sam
there's 2 ways
1) in zip file at the end of this instructable
2) by folowing this link: http://www.kicadlib.org/
look at the bottom of the page "RouleBot" in Example Circuits chapter
Mic
email: subhashish09@gmail.com
for what detail can you tell me ?
je viens de decouvrir le site du groupe Instructables Francais, alors pour ceux qui sont interresse, a la fin de mon instructable il y a un fichier ZIP qui contient le PDF en Francais et en Anglais et les schemas et PCB pour le Logiciel (gratuit) de conception electronique Kicad.
e.g. Auto Ship Program?
Ship button?
would Ship be 'boot' then you probably translated from Dutch or German :-)
Anyway, great tutorial but would be better with a better translation :-)
Need some help?
Auto Ship Program is Erase and program ship green icone
Chip = Integrated Circuit Component ( morceau de silicium )
I believe you wanted Auto Chip Program and Erase Chip in your descriptions.
L'écriture correcte est (Auto Chip Program) et (Erase Chip)
I use this web page which also performs a "back translation" to let me know if it is correct.
http://text-to-speech.imtranslator.net/default.asp
J'utilise cette page Web qui exécute aussi une 'traduction contraire'. Cela me permet de voir si c'était correct.
merci pour le lien :)
ie. the other word for IC in french is 'flea'.
I suppose it is because it is small like a flea, and will jump if you try to pick it up with tweezers. No-one really uses 'morceau de silicium' because it is too long.
I like your instructible. Good job.
Bravo !
Dommage qu'il n'y ai pas aussi les commentaires en Français.
Continuez !
j'utilise souvent Google translation pour traduire
et maintenant j'ai ce nouveau lien de askjerry,
je vais le tester
sur Kicad librairies, il y a aussi des réalisations en Français
en bas de la page
Design agréable. Je suis heureuse aussi de voir que je ne suis pas la seule personne qui utilise BASCOM pour programmer en BASIC.
sorry: (
I had packed in the zip I have to redo it
you can download it at the end of my instructablesous name:
RouleBot122ATtiny13-a.zip
merci pour ce tuto,
mais peux tu le faire en français aussi?
=D
à la fin du tuto il y a le fichier zip , tu le décompresses
et dans le dossier Images il y a le pdf en Français et en Anglais.
a+
Je suis americain.
However, I only know a petit amount of français.
in which region of America ?
Me I live in the north west of France in the Pays de Loire
Google translation is good to talk in another language,
I use it in case of difficulty
I have only started soldering and have enough difficulty with the normal size components. I so admire anyone who has mastered the art of SMD work.
