3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Mini 2-wheel robot with IR sensor weight 14gr and ATTiny13 Soic
Hi From France !
My name is Mic
Sorry for my English (:
My purpose a Very Small Bot
A little easier to build for Robot can we have patience and a good magnifyingglasses,
Its name: Roule_Robot
His nikename: RR
Curb Weight: 14gr
Dimensions: 39 x 22 mm
the necessary components:
An ATtiny13 SOIC
2 micro motor 3 volts 6mm length 12mm diameter (there are on ebay)
2 PNP transistors smd 600mA
22µF tantalum capacitor smd 1
Resistance 2 smd 6.8 K
2 10K smd resistor
1 red LED smd
An IR LED 2mm CQY37N
An IR sensor IS471F
A male strip SIL
A LiPo battery 3.7 Volts 70 mA
wheels made with the box tops tablets
they are stuck with glue or araldite cyanolite, just put in on the end of the shaft and be
careful it does not flow into the engine if not done for
motors and the battery are replacement parts for Mini Helicopter
The PCB is double sided but I avoided this by routing method on the component side with
wire phone
must also clean the PCB with acetone once finished welds.
Note: the programming is done directly in BASCOM ISP
we must remove the jumper SW1 (if not the ship is not recognized randomly)
and recover from the operation of the IR sensor
programming:
demo version of BASCOM April
the program is simple and there is room in the flash memory there
is also theATtiny13 and two free ports
and we can add lights for example.
The ZIP file contains all the pcb made ​​with Kicad and 3D components made ​​with Wings3D
images of 3D PCB are kicad screenshot of 3D rendering
Kicad wings3d and are both freewares
Step 1Tools
Tools
a pair of fights 3x magnifier
A tweezers with small beaks
A keyless tweezers
A soldering iron very fine tip
A UV PCB  exposure machine
perchloride for PCB burning
An epoxy plate presensitized 16/10
transparent to an inkjet printer or better laser printer
1 decimetre
1 metal saw
welding of: 1 mm max
Kicad software for printing the transparent
28 comments
May 25, 2012. 1:45 PMsubrotradeindia says:
hi can you provide me detail for some discussion
email: subhashish09@gmail.com
Jan 20, 2012. 3:03 PMDavid97 says:
(removed by author or community request)
Jan 19, 2012. 7:52 AMdiy_bloke says:
Very interesting. I presume english is not your native language coz the translater (Google?) has kinda meashed up yr description.
e.g. Auto Ship Program?
Ship button?
would Ship be 'boot' then you probably translated from Dutch or German :-)
Anyway, great tutorial but would be better with a better translation :-)
Need some help?
Jan 19, 2012. 1:43 PMaskjerry says:
Ship = Boat ( bateau  / navire) or Mail ( expédiez )
Chip = Integrated Circuit Component ( morceau de silicium )
I believe you wanted Auto Chip Program and Erase Chip in your descriptions.
L'écriture correcte est (Auto Chip Program) et (Erase Chip)
I use this web page which also performs a "back translation" to let me know if it is correct.
http://text-to-speech.imtranslator.net/default.asp
J'utilise cette page Web qui exécute aussi une 'traduction contraire'. Cela me permet de voir si c'était correct.
Jan 20, 2012. 10:27 PMschkip1973 says:
l'autre mot pour IC en francais, c'est "le puce"
ie. the other word for IC in french is 'flea'.
I suppose it is because it is small like a flea, and will jump if you try to pick it up with tweezers. No-one really uses 'morceau de silicium' because it is too long.
I like your instructible. Good job.
Jan 19, 2012. 1:34 PMbricmic says:
Ah ! ben enfin une réalisation en français !
Bravo !
Dommage qu'il n'y ai pas aussi les commentaires en Français.
Continuez !
Jan 20, 2012. 12:12 AMsid98 says:
wah alil nice bot
Jan 19, 2012. 7:25 AMaskjerry says:
Nice design. I am also glad to see that I am not the only person who uses BASCOM to program in BASIC.
Design agréable. Je suis heureuse aussi de voir que je ne suis pas la seule personne qui utilise BASCOM pour programmer en BASIC.
Jan 19, 2012. 7:54 AMdiy_bloke says:
Ah, I see u might be French :-)
Jan 17, 2012. 1:29 AMapburner says:
I have downloaded the zip file but cannot find the KICAD files.
Jan 17, 2012. 6:11 AMapburner says:
Thank you Mic100. Nice instructable and pretty board.I really need to learn KICAD. I have 10 attiny85's I need to do something with.
Jan 17, 2012. 5:21 AMmax_fraser says:
cool stuff, really awesome project!
Jan 16, 2012. 1:45 PMabachelier says:
Salut,
merci pour ce tuto,
mais peux tu le faire en français aussi?
=D
Jan 16, 2012. 10:37 PMabachelier says:
Ok, merci beaucoup et bonne continuation!
Jan 16, 2012. 8:48 PMblinkyblinky says:
Bonjour.
Je suis americain.
However, I only know a petit amount of français.
Jan 17, 2012. 2:09 PMblinkyblinky says:
Je suis de New York.
Jan 15, 2012. 1:12 PMProBodger says:
Great. I love it, a real programmable micro robot.
I have only started soldering and have enough difficulty with the normal size components. I so admire anyone who has mastered the art of SMD work.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:Mic100
