Mini 3D Christmas Tree Craft
Introduction: Mini 3D Christmas Tree Craft
Hi guys, you'll learn to make an easy mini 3D Christmas tree with seed beads and wires! Hope you'll love it! More tutorials from LC pandahall
Step 1: Supplies
0.5mm light orange brass wire
4mm green glass seed beads
4mm ivory glass pearl beads
Flat nose pliers
Wire cutter
Step 2: Make the Tree’s Top Layer
1st, pick a 50cm length of brass wire and string 4 green beads and 1 ivory pearl on;
2nd, back the wire through the green beads and tighten it;
3rd, secure beads by twining the wire ends around each other;
4th, string 3 green beads and 1 pearl on wire end and repeat above process;
5th, when finishing five 3-green-bead branches, twine the wire ends together;
6th, the 4-green-bead branch is the Christmas tree’s top, and the whole is the top layer.
Step 3: Make the Tree’s Middle Layer
1st, pick a 55cm length of brass wire and string 4 green beads and 1 pearl on;
2nd, refer to step 1 to make other branches, but be noticed that each branch in this layer consists of one pearl and 4-6 green beads;
3rd, finishing 7-8 branches, twine the wire ends together;
4th, make 3 such middle layers.
Step 4: Make the Bottom Layer
1st, pick another 55cm length of brass wire and string 10 green beads and 1 pearl;
2nd, still repeat step 1 processes, and the green beads range from 6-10;
3rd, at last twine the wire ends together to finish the 1st bottom layer;
4th, repeat to make another two.
Step 5: Assemble the Layers Together
1st, connect middle layers to top layer with a 1.5cm interval in between;
2nd, similarly connect bottom layers to top and middle layers;
3rd, twine all the wire ends together.
Step 6: Finish the Tree’s Stem
1st, leave 3cm length for tree’s stem, bend the rest wire up;
2nd, twine the wires around each other.
Step 7: Tada!
I have finished this mini Christmas tree! Let me know if you love it or not. Merry Christmas!
    • Pocket-Sized Contest
    • Paper Contest 2018
      Paper Contest 2018
    • Trash to Treasure
      Trash to Treasure
