Mini 3D Printed Bluetooth Speaker
1,390
17
Published
Introduction: Mini 3D Printed Bluetooth Speaker
About: Enthusiastic about electronics, RC 3D printing and IT! A devoted maker and DIY fan! Business owner! https://32bitbrad.co.uk
A mini Bluetooth speaker would be great to take around, and after I saw these little Bluetooth audio amplifier module I thought I’d build one for myself. I’d already built a massive Bluetooth speaker, utilising an old 60W speaker from a hi-fi system, so I had a good understanding of what needed doing. Ideally, I’d like a small, compact Bluetooth speaker that has great volume and is easily rechargeable.
Step 1: ​Planning and Specification
I had most of the components for this project on hand, all I needed to buy was the Bluetooth module and an 18650 lipo battery and charger board. This came to about £6 all togeather, pretty good. As this is a hobby project, I wasn’t stuck to any schedule or deadline, but I wanted to finish this project quickly. Specification Small and compactLoudRechargeable via micro USBBluetooth connectivityPower Switch to save battery
Step 2: Design and Project Development - 3D Modeling
I started by ordering all the necessary components needed for this project, which came to about £6. The battery and charging board actually came from Poundland, they have portable chargers which make great project batteries. I then created a casing design, using tinkerCad, The new Beta version is actually really good, this design took em about an hour to create.
Step 3: Design and Project Development - Speaker Test
I quickly tested the Bluetooth module and speaker, making sure it worked. Which it did, rather well actually! I used a USB power meter, which read that the 5V output was holding and a max power draw of about 15mA. This means that in theory, the speaker can last up to 42 hours… Something is not right there! XD
Step 4: Design and Project Development - Printing
I then printed the design which was eventful, to say the least. The print was a nightmare to get started and them, when it did stick little bits of old plastic, stuck onto the print. This is because I needed to replace my hotend, after its long-term use.
Step 5: Design and Project Development - Assembly
After using the above print to confirm that all my measurements were correct, I added my logo to the casing design. I converted my logo to an STL file, using Img to STL, a free file converter I found on Thingiverse. I then cleaned up the STL file using the ‘Make it printable‘ online 3D model repair tool. Then, I imported this logo STL into tinkered, and make an indented logo on the top of my case!
Step 6: Design and Project Development - Final Product
As you can see, the speaker works really well. It’s really loud, especially for the size!
Improvements
One improvement I think I’ll make is the casing (again). The speaker is a little exposed to damage, so a simple mesh or cover to protect this a little more would be a good idea. Also, I’d print the casing in a darker colour, as the internal LEDs (The charging module and speaker module) conflict a little, which is a bit annoying.
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    • Planter Challenge
      Planter Challenge
    2 Comments
    Jason, check out 3D hubs! It is an online platform that allows you to get 3D printed parts from printer owners around you. Also if you use Fusion 360, you are able to directly export the file to a printing service. The beauty of technology is that everyone has access to a 3D printer! Can't wait to see what you make
