Introduction: Mini Alcohol Stove.
This is a tutorial on how to make a Mini Alcohol Stove!, which is pocket sized so can be taken anywhere with you. This is a great item to have when, hiking camping or just to have to add to your collection of DIY items!, We hope you enjoy making this Alcohol stove as much as we did! Enjoy!
Step 1: Step 1.
Materials you will need ...
1. Aluminium cans x2. (empty)
2. Some fibre glass.
3. Scissors.
4. Sharpie Marker.
5. Ruler.
6. Thick book ( Preferably Argos catalogue, to rest pen on. )
7. Sharp knife.
8. Thumb tacks.
Step 2: Step 2.
Now that you have all your Materials, Start by emptying the aluminium cans and washing them out thoroughly.
Step 3: Step 3.
Now that you have emptied the can of all its discharge, Measure from the bottom of the can upwards, 1 Inch, Lean your Sharpie permanent marker on a book so that the line is straight all the way around the can. Now holding the pen in position, begin to spin the can around until a full line has occurred.
Step 4: Step 4.
Now that you have your line drawn all around the can, Pierce the middle of the can with a knife and begin to work your way to the line with a pair of scissors. Try to be as accurate as possible at this point.
Step 5: Step 5.
Now that you have cut down the line on both cans as accurately as possible, you should have something like this ... !
Step 6: Step 6.
Now, On only one of the cans, You want to sand the paint off. You want to do this as well as possible! This will improve the look of your finished product!. This might be hard though as the can has lots of dints that are not visible when paint is aplied. So just do the best you can and remember not to sand to hard or you will put a hole in the aluminium.!
Step 7: Step 7.
Now that you have the can sanded to the best of your ability, you will need to crimp the edge of the can that still has paint on it, so that the cans fit together later on in a next step! You will need to do this with a small pair of needle nose pliers or something very similar.
Step 8: Step 8.
Now get some fibre glass and cram it in the bottom of the can which has paint on and has crimped edges. You can find fibre glass in your loft, As it is used for insulation! (For those of you who do not no.)
Step 9: Step 9.
We have almost done!, Now all you have to do is get a thumb tack and create 9 air vents. We found that it is best to do 8 vents around the edge and one in the middle. The hole in the middle is used to pour the Alcohol into and the holes around the edge are used as jets for flames like on your gas cooker!
Step 10: Step 10.
Well done! you have finished putting together you mini alcohol stove!
To fuel the stove you can use rubbing alcohol or Heat (American product)
Just pour into the filling hole in the middle, give it a second for the fibre glass to soak
it up and then light it up and watch it go! Give it a few minutes before putting pots or pans on and your Mini Alcohol Stove should work like a charm! Hope you liked the Instructable!
Pocket-Sized Contest
