The title has it all, you've seen the original Altoids Grill that uses small pieces of charcoal or even alcohol. We made the first Butane Lighter Altoids Gas Grill...
Keep in mind that this is not really safe for actually cooking something on it, but you can heat up water, pans, etc.
We hope y'all enjoy this 'able Here is the video link http://blip.tv/file/3059844 just in case y'all don't want to take the time to read out the FULL Instructable
Enjoy :)
Remove these ads by
Signing UpStep 1Getting your supplies
You need to obtain to get the following items.
Most importantly you need to get an Altoids Box A large one from the classic Altoids, and an Altoids Mini box.
Next you need a coat hanger that has no plastic coating on the outside of the wires.
You need to obtain a hacked lighter, you can find out how to make one by watching our Hacked Lighter video on this link Hacked Lighter
You also need a bullet plug, you can find them at Radio Shack
and several pieces of aluminum tape in order to wrap up the burner.
and lastly you need to get a small coffee straw or a straw from the end of a compress air blower.
Compressed flammable gas + ignorance = explosive event / bad outcome.
Better option use a can stove.
Kids screwing around with valves on lighters = bad idea.
If that thing is going (watch the lighter hack part) while Jr. has it full throttle and it comes apart - POOF!.
Think about kids -v- intelligence, they get enough ideas on their own, I know I was one.
Exploding light trick would be very hard to do with this though.
I can just see 2 12yr olds bent over this, using the biggest lighter they can find, when the valve they've almost completely unscrewed lets go while young Jimmy is holding a lit match.
BOOM!!
Don't believe me, go ask the staff at the local burn unit.
trust me my dad used to be a welder he knew his stuff
A lighter rapidly venting in a fire has immediate combustion.
A light that vents NEAR a combustion source creates a gaseous cloud that ignites on Jimmy's lit match.
The difference is whooosh versus BOOM!!
http://www.youtube.com/watch?v=j9xCgNdZPKk
Never heard of the exploding house due to a gas leak?
Mentioning an exotic HE fuel/are explosive in the same sentence as a butane mini stove it quite amusing... I am indeed amused...
I was one of those kids who opened the valve all the way and lit the still very isolated sputters of liquid butane with another lighter. I and my friend screwed around with the little refill canisters til they were empty. we use to fill our mouths with gas by pressing the nozzle against our teeth. heads tilted back , a gentle blow and a lighter, woof. you get a little heat in your face. (keep in mind we hoolagins were attending a private school for the "gifted and talented.")
A little butane lighter is about as dangerous as a kitchen stove. it's not in huge quantities under pressure in the way oh... a full sized LP grill might be? I think something that size and fuel and pressure might pose the sort of threat you're talking about.
this is sweet
make another one where you use a stick lighter
they have a built in electiric sparker and a good length of tubeing ment for butane
plus no matches to start it!
Hydrocarbon + Oxygen —> Carbon + H2O
