Introduction: Mini Arduino Environment Monitor ** UPDATE - Added RTC ***
This is an Example of how you can use the Arduino to monitor various environmental parameters And display them on a LCD screen.
Note: I Added a Real Time Clock!! To see the steps, added parts  and Sketch I added new steps..
Step 1: Parts List
Arduino uno R3 or compatible                                           30.00
Sainsmart "1.8" TFT Color LCD Display                          18.50
DHT11 Digital Temperature and Humidity Sensor        6.44
Mini Breadboard        5.00
Jumper Wire
Step 2: Connect Display to Arduino
I used the mini breadboard to connect the display to the Arduino.
Use jumper wires to connect from the Arduino pins to the breadboard in the following order:
Arduino:  5v         TFT DISPLAY   VCC
                 gnd                                 GND
Digital     4                                      SCL
                 5                                     SDA
                 6                                     CS
                 7                                     DC
                 8                                     RES
Step 3: Test the Display
In order to test the display, you will need to download and install two libraries into your Arduino IDE. Although the display is sold by Sainsmart, I had trouble using their libraries and downloaded the libraries from ADAFRUIT, who sells a similar display and has  much better  documentation and support..I'd normally feel a little guilty about ordering these from SainSmart and using the Adafruit instructions and libraries, but I purchase enough other stuff from Adafruit to appease my conscience. If you end up taking the same route I did, I encourage you to at least look at the other stuff they offer.
Two libraries need to be downloaded and installed:  The first is the ST7735 library (which contains the low-level code specific to this device). The second is the Adafruit GFX Library (which handles graphics operations common to many displays that Adafruit sells). Download both ZIP files, uncompress and rename the folders to 'Adafruit_ST7735' and 'Adafruit_GFX' respectively, place them inside your Arduino libraries folder and restart the Arduino IDE.
You should now be able to see the  library and examples in  select File > Examples > Adafruit_ST7735 > graphicstest sketch. load the sketch to your Arduino.
If you were successful at installing the libraries, and loading the graficstest sketch,  Click on the verify button to compile the sketch and make sure there are no errors.
It's time to connect your Arduino to your PC using the USB cable, and  click on the upload button  to upload the sketch to the Arduino.
Once uploaded, the Arduino should perform all the test display procedures! If you're not seeing anything - check to see if the back-light is on, if the back-light is not lit, something is wrong with the Power  wiring. If the back-light is lit ,but you see nothing on the display recheck the digital signals wiring.
If everything is working as expected, we are ready to  wire up the DHT sensor.
Step 4: Connect the DHT11 Sensor to the Arduino
As with the display, I used jumper wires to connect the required power and data pins for the DHT11  using the mini Breadboard. Line up the pins and then plug in the sensor.
Looking at the front of the sensor:
From Left to Right
connect pin 1 of DHT11 to 5 V, Pin 2 to Digital Pin 2 of the Arduino, Pin 3 no connection, and Pin 4 to Arduino GND.
That's It!
Step 5: Test the DHT11 Sensor
You need to download another Library  to get the Arduino to talk with the DHT11 sensor. The sensor I got didn't come with any documentation, so I Googled around until I found a library that works.
I found it in the Virtualbotix website
As with the display  libraries, Download the library unzip it,  and install it in the Arduino IDE. Place it inside your Arduino libraries folder , rename it  DHT11, and restart the Arduino IDE.
You should now be able to see the  library and examples in  select File > Examples > DHT11 > dht11_functions sketch.
If you were successful at installing the libraries, and loading the dht11_functions sketch,  Compile the sketch  by clicking on the verify button and make sure there are no errors.
It's time to connect your Arduino to your PC using the USB cable.  Click on the upload button  to upload the sketch to the Arduino.
Once uploaded to the Arduino, open the serial monitor, and you should see the data stream  with information coming from the sensor.
If you got the sensor working, we're now ready to display the data on the TFT Screen..
Step 6: Final Step, Displaying Sensor Data on the TFT
// copy the sketch below and paste it into the Arduino IDE compile and run the program.
// this sketch was created using code from both the adafruit and the virtuabotix sample sketches
// You can use any (4 or) 5 pins
#define sclk 4
#define mosi 5
#define cs   6
#define dc   7
#define rst  8  // you can also connect this to the Arduino reset
#define ANALOG_IN 0 // for cds light sensor
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library
#include <SPI.h>
#include <dht11.h> // dht temp humidity sensor library
dht11 DHT11;
Adafruit_ST7735 tft = Adafruit_ST7735(cs, dc, mosi, sclk, rst);
void setup(void) {
  DHT11.attach(2); // set digital port 2 to sense dht input
  Serial.begin(9600);
  Serial.print("hello!");
  tft.initR(INITR_BLACKTAB);   // initialize a ST7735S chip, black tab
  Serial.println("init");
  //tft.setRotation(tft.getRotation()+1); //uncomment to rotate display
// get time to display "sensor up time"
  uint16_t time = millis();
  tft.fillScreen(ST7735_BLACK);
  time = millis() - time;
  Serial.println(time, DEC);
  delay(500);
  Serial.println("done");
  delay(1000);
tftPrintTest();
  delay(500);
// Splash screen for esthetic purposes only
  // optimized lines
  testfastlines(ST7735_RED, ST7735_BLUE);
  delay(500);
  testdrawrects(ST7735_GREEN);
  delay(500);
void loop() {
// tft.invertDisplay(true);
// delay(500);
//  tft.invertDisplay(false);
tft.setTextColor(ST7735_WHITE);
tft.setCursor(0,0);
  tft.println("Sketch has been");
  tft.println("running for: ");
  tft.setCursor(50, 20);
  tft.setTextSize(2);
  tft.setTextColor(ST7735_BLUE);
  tft.print(millis() / 1000);
  tft.setTextSize(1);
  tft.setCursor(40, 40);
  tft.println("seconds");
  tft.setCursor(0, 60);
  tft.drawLine(0, 50, tft.width()-1, 50, ST7735_WHITE); //draw line separator
  tft.setTextColor(ST7735_YELLOW);
  tft.print("Temperature (C): ");
  tft.setTextColor(ST7735_GREEN);
  tft.println((float)DHT11.temperature,1);
  tft.print("Humidity    (%): ");
  tft.setTextColor(ST7735_RED);
  tft.println((float)DHT11.humidity,1);
  tft.print("Temperature (F): ");
  tft.println(DHT11.fahrenheit(), 1);
  tft.print("Temperature (K): ");
// tft.print(" ");
  tft.println(DHT11.kelvin(), 1);
  tft.print("Dew Point   (C): ");
  tft.println(DHT11.dewPoint(), 1);
  tft.print("DewPointFast(C): ");
  tft.println(DHT11.dewPointFast(), 1);
  tft.drawLine(0, 110, tft.width()-1, 110, ST7735_WHITE);
  tft.setCursor(0,115);
  tft.print("Light intensity ");
int val = analogRead(ANALOG_IN);
  tft.setCursor(60, 130);
  tft.println(val, 1);
  delay(2000);
void tftPrintTest() {
  tft.setTextWrap(false);
  tft.setTextSize(2);
  tft.println("temperature");
  tft.setTextSize(2);
  tft.println("humidity");
  tft.setTextSize(2);
  tft.println("monitor");
  //tft.setTextSize(3);
  //tft.print(3598865);
  delay(500);
void testfastlines(uint16_t color1, uint16_t color2) {
  for (int16_t y=0; y < tft.height(); y+=5) {
    tft.drawFastHLine(0, y, tft.width(), color1);
  for (int16_t x=0; x < tft.width(); x+=5) {
    tft.drawFastVLine(x, 0, tft.height(), color2);
void testdrawrects(uint16_t color) {
  for (int16_t x=0; x < tft.width(); x+=6) {
    tft.drawRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color);
Step 7: Bonus ! a Light Sensor Using Analog Input
As an Added bonus, you can monitor any analog signal using one of the Arduino analog inputs. As an example , I  will use a CDS photo resistor to monitor Light intensity.
You Wil need:
1 CDS photo-resistor
1 10 K ohm resistor
Steps:
Connect the resistor and  CDS photocell in series in an unused space in the mini breadboard.
Connect the open leg of the photocell to the +5v
Connect the open leg of the resistor to  GND
Connect the CDS Resistor Junction to the Analog input 0 of the Arduino (the code to monitor the input is already in the sample sketch)
You're done!!
You can monitor virtually any  analog parameter using this input method: i.e Sound level, wind speed, vibration etc...
Step 8: Video of Running Prototype
I Don't Know how to embed a video, so here's the link to youtube where you can see it in action.
http://www.youtube.com/watch?v=ZaEn8vhsrsg&feature=youtu.be
Step 9: UPDATE: Added an Ultrasonic Sensor and Modified Program to Just Update the Numbers
// Program now only refreshes numbers and added range meter. will post another instructable with the progress soon
#define sclk 4
#define mosi 5
#define cs   6
#define dc   7
#define TRIGGER_PIN  12  // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN     11  // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 200 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
#include <SPI.h>
#include <NewPing.h> // S04 Ultrasonic sensor Library
dht11 DHT11;
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
void setup(void) {
  Serial.begin(115200);
// Serial.println(time, DEC);
// delay(500);
// Serial.println("done");
// delay(1000);
tftPrintTest();
  delay(500);
  tft.fillScreen(ST7735_BLACK); // Clear screen
  // commented lines below are  Grid and Square splash Screen
//  optimized lines
//  testfastlines(ST7735_RED, ST7735_BLUE);
//  delay(500);
//  testdrawrects(ST7735_GREEN);
//  delay(500);
void loop() {
  // delay(500);
  tft.setTextSize(1);
  tft.setCursor(0,0);
  tft.setTextSize(2);
  tft.setTextColor(ST7735_BLUE, ST7735_BLACK);
  tft.setTextSize(1);
  tft.setTextColor(ST7735_GREEN, ST7735_BLACK);
  tft.setTextColor(ST7735_RED, ST7735_BLACK);
// tft.print(" ");
  //tft.setCursor(60, 130);
   tft.setTextColor(ST7735_YELLOW, ST7735_BLACK);
  //delay(2000);
  delay(500);                      // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
  unsigned int uS = sonar.ping(); // Send ping, get ping time in microseconds (uS).
  tft.setCursor(0,130);
  tft.print("Distance: ");
  tft.print(uS / US_ROUNDTRIP_CM); // Convert ping time to distance and print result (0 = outside set distance range, no ping echo)
  tft.setTextColor(ST7735_RED,ST7735_BLACK);
  tft.print(" cm   ");
  delay(50);
// tft.fillScreen(ST7735_BLACK);
  tft.setCursor(0, 10);
  tft.setTextSize(1);
  tft.println("INSTRUCTABLES.COM");
  delay(500);
  tft.setTextSize(2);
  tft.setTextSize(2);
  tft.setTextSize(2);
  delay(50);
Step 10: Latest Stream- Lined Code (sketch) Build. Runs Faster, Looks Better!
// Sketch Build 1.04 compiled on Arduino 1.0.3. Changes from last build: moved static prints to void setup, cleaned up void loop redundant code.
// This sketch was modified to run the loop faster.. refresh rate is about 1.5 seconds.
// copy the sketch below and paste it into the Arduino IDE verify, and run the program.
// this sketch was created using code from the adafruit,the virtuabotix, and newPing sample sketches
#define sclk 4
#define mosi 5
#define cs   6
#define dc   7
#define rst  8
#include <SPI.h>
#include <dht11.h> // DHT11 temp humidity sensor library
dht11 DHT11;
void setup(void) {
  DHT11.attach(2); // set digital port 2 to sense DHT11 input
  uint16_t time = millis(); // time calculations to display sketch runtime in seconds
//tftPrintTest(); //Initial introduction text, uncomment to view on screen
// *** Printing static Items on display in the setup void in order to speed up the loop void****
  tft.fillScreen(ST7735_BLACK); //  clear screen
  tft.setTextSize(1);
  tft.setCursor(0,0);
   tft.println("Temperature (C): ");
   tft.println("Humidity    (%): ");
   tft.println("Temperature (F): ");
   tft.println("Temperature (K): ");
   tft.println("Dew Point   (C): ");
   tft.println("DewPointFast(C): ");
void loop() {
  tft.setTextSize(2); //set text size for seconds
  tft.setTextColor(ST7735_BLUE, ST7735_BLACK); // set color for seconds
  tft.setTextSize(1); //set text size for all data coming from DHT11
  tft.setCursor(98, 60);
  tft.setTextColor(ST7735_GREEN, ST7735_BLACK); // set color for all data coming from DHT11
  tft.print((float)DHT11.temperature,2);
  tft.setCursor(98, 68);
   tft.print((float)DHT11.humidity,2);
  tft.setCursor(98, 76);
   tft.print(DHT11.fahrenheit(), 2);
  tft.setCursor(98, 84);
    tft.print(DHT11.kelvin(), 1);
  tft.setCursor(98, 92);
   tft.print(DHT11.dewPoint(), 2);
  tft.setCursor(98,100);
   tft.print(DHT11.dewPointFast(), 2);
  tft.setCursor(98,115);
  int val = analogRead(ANALOG_IN); // READ LIGHT SENSOR VALUE
  tft.setTextColor(ST7735_YELLOW, ST7735_BLACK); //set light sensor data text color
  tft.print(val, 1); // PRINT LIGHT SENSOR VALUE
  tft.print("  ");
  delay(50);                      // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
  tft.print(" cm   ");
  delay(50);
  tft.setTextSize(1);
  delay(500);
  tft.setTextSize(2);
  tft.setTextSize(2);
  tft.setTextSize(2);
   delay(50);
Step 11: Add a Real Time Clock to Monitor
To Add a real time clock to the monitor, you will need:
A TinyRTC Module
4 Jumper wires
The Wire Library
The RTC Library
Step 12:
To Connect the TinyRTC to the Arduino, Refer to the Diagram and:
Connect the RTC VCC  to the Arduino  +5 v
                       RTC GND to the Arduino GND
                       RTC SDA to  the Arduino Analog Pin 4
                       RTC SCL to  the Arduino Analog Pin 5
Step 13: Install the Required Libraries
You need to  install the required libraries:
Wire Library -This library is included with the Arduino IDE
RTC Library - Have uploaded this library for your convenience, download it and place it inside your Arduino libraries folder.
If you were successful at installing the libraries,  load the RTClib>DS1307  sketch,  Compile the sketch  by clicking on the verify button and make sure there are no errors.
Once uploaded to the Arduino, open the serial monitor, and you should see data   with information coming from the TinyRTC
If you got the TinyRTC  working, we're now ready to display the data on the TFT Screen..
Step 14: Upload the Sketch Below to Get Time and Temperature in Your Mini Display!
// this sketch was created using code from the adafruit-libraries
#define sclk 4
#define mosi 5
#define cs   6
#define dc   7
#define rst  8
#define ANALOG_IN 3 // for cds light sensor
#include <SPI.h>
#include <Wire.h> // library needed for RTC
#include "RTClib.h" //RTC Library
RTC_DS1307 RTC;
dht11 DHT11;
void setup(void) {
Wire.begin();
RTC.begin();
void loop() {
  tft.setCursor(10,0);
  tft.setTextSize(1);
   tft.setTextColor(ST7735_YELLOW,ST7735_BLACK);
   tft.setTextSize(1);
    tft.setCursor(30,10);
    DateTime now = RTC.now();
    tft.print(now.year(), DEC);
    tft.print('/');
    tft.print(now.month(), DEC);
    tft.print('/');
    tft.print(now.day(), DEC);
    tft.println(' ');
    tft.setCursor(15,25);
    tft.setTextSize(2);
    tft.setTextColor(ST7735_BLUE,ST7735_BLACK);
    tft.print(now.hour(), DEC);
    tft.print(':');
    tft.print(now.minute(), DEC);
    tft.print(':');
    tft.print(now.second(), DEC);
    tft.println(" ");
  tft.print("  ");
  tft.setTextSize(1);
  delay(500);
  tft.setTextSize(2);
  tft.setTextSize(2);
  tft.setTextSize(2);
   delay(50);
Arduino Contest
Second Prize in the
Arduino Contest
Battery Powered Contest
Finalist in the
Pocket Sized Electronics
