Introduction: Mini Back to the Future Hoverboard
Picture of Mini Back to the Future Hoverboard
This is my first instructable and as a huge back to the future fan I made this cheap DIY BTTF hoverboard. I prepared some templates for the mini version. This is a great project to do with the kids. I know Christmas is far away but you can use it as an ornament. Or anything you want. I hope you have fun making this hoverboard, and thanks for looking!
I found most of these materials around my house and at the dollar store.
Materials:
Scissors
Elmers glue and hot glue
Tracing tool (pen or pencil)
CD or pie tin
Black tape
A dish to put glue in
Foam sheets
Pink and red paint
Step 1: Print and Cut
Picture of Print and Cut
I got full size templates from this website I found. If you want to check them out I put the links below.
Templates: 123
I took these templates and re-sized them to a miniature version. Here are the links to my re-sized hoverboard templates.
Re-sized Templates: 1 2
Make sure to cut on all solid lines. Also for the blank hoverboard template cut on the second line at the curve on top, not the first line.
The only template I drew were the circles. There are 5 circles. 3 with the diameter of 2 in and the other 2 have diameters of 1 3/4 of an inch.
Step 2: The Body
Picture of The Body
1. I took foam sheets I had and traced the blank template 4 times.
2. To make the body stiff I traced and cut a piece of cardboard to place in the middle of the foam.
3.The bottom most line on the template is where the bend is on the hoverboard. I bent the cardboard about 25 degrees to make the bend.
4. I then glued each piece together. You can use hot glue or liquid glue. Note that the hot glue dries faster and you have to press down on the body so it is not bulky.
5. I then used tape to smooth the edges out. Make sure that there is no bumps or air bubbles from the tape or glue because it will effect the painting process.
Step 3: Painting!
Picture of Painting!
1. I got some pink paint and painted everywhere on the board.
2. After the paint has dried I took about 2 tablespoons of Elmers glue and mixed it with a 1/2 teaspoon of water. I took the mixture and brushed it everywhere I put paint. This made a glossy hard shell over the body of the board.
3. When you have all the paint out I decided to paint the connectors red.
Step 4: Using the Templates
Picture of Using the Templates
1. I took the battery pack template and traced it on a piece of a purple foam sheet.
2. I did the same for the bigger circle and covered it with electrical tape or any black tape.
3. I traced the smaller circle template on a CD and cut it out. You can also use any silver material that won't wrinkle like tin foil.
4. I traced the bigger circle on a piece of light green foam sheet. I also cut a small sliver of pink foam sheet.
Step 5: A Sticky Situation
Picture of A Sticky Situation
1. I looked up on google a picture of the hoverboard bottom from Back to the Future and followed that format.
2. I put some Elmers glue on the each of the pieces and glued it on the correct places
Step 6: Final Thoughts and Changes
Picture of Final Thoughts and Changes
This is my first time making this hoverboard so yours will be better than mine. I am working on a BTTF hoverboard that works using magnets. I realized the material I used was to heavy for magnets but can still hover over a fan. The other hoverboard will use the same templates but lighter material.
About This Instructable
1,595views
11favorites
License:
Bio: I'm a high school student that has multiple hobbies
More by angidiy:Beginning on the TrumpetPumpkin Spice ice creamWakeboarding Fail and Success
Add instructable to:
