Introduction: Mini-Beading Loom Travel-Size
Mini Beading Loom Tutorial...travel size!!
On my recent trip to Florida I wasn't able to bring all my craft supplies, but I knew I would want to do some beading during some down time between Disney park visits....
So I decided to make a mini travel-sized loom to take and I wanted to share the process with you:
Step 1: Ingredients....
Supplies:
Wood pieces 1" thick cut to desired size (I cut one piece 3" width by 6"length, and two smaller pieces each 3" width by 1.5"-approx.-in length)
2 Eye Screws, 4" bolts, two wing nuts to fit bolts
Wood Stain (if desired)
Wood Glue and 2 clamps to secure while drying
Drill, Sand paper or electric sander
Step 2: Cut Your Wood Pieces...
First, cut your wood to dimensions listed in "Ingredients" section in the last step:
Step 3: Sand and Stain Wood (if Desired)...
Next, if desired, sand edges and surface of wood till smooth and stain with wood stain in desired shade:
Step 4: Glue Small Pieces to Large Piece of Wood....
When the stain has dried, use wood glue to connect the 2 smaller pieces to the top side ends of larger wood piece and add clamps to hold in place while drying as shown:
Step 5: Drill Holes....
After the glue has dried, drill 4 holes...(2 holes in each small end piece) into the each end of the two smaller wood pieces- as shown:
Step 6: Add Eye Screws....
Add the eye screws--one to each of the 4 holes and use the bolts to screw them in tight (see 2nd picture):
Step 7: Add the Bolts, Wing Nuts, Etc.....
Add bolts through the eye screws and secure with wing nuts on both ends as shown in picture....
ALSO: Add two nails to each outer edge (if desired - not shown) to use to secure thread when threading the loom....
** There you have it. A mini bead loom to take along with you!
Let me know if anything is unclear in comment section and I will get right back to you. Also, if you want to make a larger loom, check out my other tutorial either here on Instructables or on my blog at:
wickedjypsi.blogspot.com (Link: HERE)
