Mini Brake Bender
3,349
31
10
Published
Introduction: Mini Brake Bender
About: I like to tinker, That is what I like to do. Sometimes I drop a rhyme, Along with a tool or two. I use what I have on-hand, I keep projects super simple. I do not need more stuff, What I do have is ample. Dr...
Introduction
A common hurdle during a project is having the right tool for the task. I am constantly faced with the perplexing questions of, do I buy the $$$ tool? Do I buy the cheap import tool? How far do I have to travel and how much time will it take? To whom do I call who might have the tool?
The Story
The other night I was faced with this hurdle. It was too late to buy a tool or find a friend who might have one. So what do I do? I made the tool I needed. The back story is I needed to bend a piece of metal around 2 corners. 1 side could only be 15/16 inches deep, 1 side could only be 1 inch wide and the last side did not have a depth limitation, it just needed to look nice. The first 2 sides were critical. I had wiggle room on the 3rd side.
Follow along for the rest of the story on how to make and use a Mini Brake Bender.
The benefits of this design and application are:
1) Small, easy to use and carry in your tool box,
2) 1 less tool to have to buy and store,
3) Knowledge does not weigh anything or take up any space.
Next Material and Tools.
Step 1: Material & Tools
Material:
I am using Stainless Steel
Tools:
1) Needle Nose Locking Pliers
2) Flat Nose Locking Pliers
3) 2 Flat Files
These are tools I had on hand. If your project is bigger you may want more locking pliers or use other pieces of flat steel to hold the metal when bending. Substitute my tool list with what you have on hand or size of your project.
Skill Level:
Easy
Time to Complete:
5 – 10 minutes
Now that you have your Material and Tools, let’s see how to make a Mini Brake Bender.
Next 1st Bend
Step 2: 1st Bend
1) Mark where you want your bend,
2) Place 1 of the Flat Files on top of the Metal, along the line of your first bend,
3) Clamp 1 of the Locking Pliers on the Metal and File,
4) Place the last Flat File underneath the Metal on the other side of the line,
5) Clamp the last Locking Plier on the Metal and File,
6) Apply force to bend the Metal.
Next 2nd Bend
Step 3: 2nd Bend
2) Place 1 of the Flat Files on top of the Metal, along the line of your second bend,
Now you are done. Congratulations! You have successfully created and used a Mini Brake Bending tool.
Next Observations and Summary
Step 4: Observations & Summary
Observations
I am all for having the right tool for the job, but I cannot afford to buy nor do I have the space to store a specialty tool for 1 off repairs. You now have the knowledge to make and use a Mini Brake Bending tool.
Summary
I am satisfied with the results.
- Hear advice, and receive instruction, so that you may be wise in your latter end.
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    10 Comments
    Have a pice to bend tomorrow. Found this today. Thanks for sharing.
    Thank you for reviewing and commenting. I hope this was helpful in your project.
    Thank you for reviewing and commenting. Totally surprised me on my first attempt. The 2nd attempt was just as successful. This had to be shared.
    I agree that having the right tool for the job is always the best. However the best tool for every job is the one between your ears and just behind your forehead. With it you can improvise or work around any tool you don't have. Your instructable is a perfect example of that. Great job!
    Thank you for reviewing, commenting, observations and your kind words. To everyone is given abilities; to some mechanical, others literary, sculpting, teaching, encouragement, etc. Use what you have been given to help those who have not. instructables is a good site to disseminate the “How to do” of DIY. Thank you for your contributions.
    Really nice "Improvise, Adapt, Overcome" Instructable. Thank you! I also enjoy the way you've encorporated Scripture into your coments. Keep up the good work!
    Thank you for your comments, observations and compliments. I am humbled to be in the service of others.
    Thanks!
