3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Mini Charcoal Furnace
This is the first charcoal furnace that  I built its purpose melting small amounts of aluminium into ingots or sand castings for small objects. I don't predict a long "shelf life" for my furnace before it will start cracking but I will get a few melts before I scrap it, This is just a prototype and hopefully in the future I will make a bigger and better furnace.
It's easy and quick to make, I will show in this instructable the steps on how to make it using materials some of us have  in our house. The only "big" money might be the refractory materials and characoal.
A few details about my furnace: I made it all 2" thick around including the furnace lid. I used Plywood, MDF, cardboard, chipboard all left overs from other jobs.
The furnace tools I made from a 5mm construction rebar, can of beans and old bathrooms hooks.
In the near future I hope to add to this instructable a few images of my first sand casting.
A few Saftey words: Coming  into contact with fire and boiling melted metal can be very dangerous so always work safe using proper full body protection including respirator mask against toxic fumes and dust from mixing refractory materials. Never melt in a wet area or near water, if water comes in contact with the boiling aluminium it might "blow" in your direction.
Step 1Furnace construction
A bit of form work: check if you have any scrap plywood, MDF etc'  to hold the refractory furnace shape.
I used scraps of plywood, MDF, chipboard, soft wood, cardboard all screwed  together.
Start with the walls and the base. Optional: making small wooden angles for the corners will make the corners flat  preventing them from breaking.
Drill a hole 2" from the base using a core bit for timber.  The diamater of the hole should fit the size of the pipe you will use for the blower.
I used a cardboard pipe to form the opening for the blow pipe.
49 comments
1-40 of 49next »
Jan 9, 2012. 2:45 PMcowscankill says:
How do you get the ingots out of the muffin tin? Haha, I have 6 stuck in the tin and I can't get them out.
Jan 1, 2012. 10:18 AMbobbuilder09 says:
hello,
i am sure i read somewhere that if the inner refactory mix is not to thick, and then surounded by a layer of sand (allows expansion) or probably ceramic wool, then a further layer of refactory insutation, then a expandable layer (you get the onion ring effect idea) then the refactory layers are allowed to expand and contract without too much stress and therefore cracking. i think some experimentation is needed.
to hold the solid layers together(at the top), some wire netting, or stainless steel wire in a zig zag fashion around the circumference (binding)between the layers would bind the whole lot together, whilst allowing expansion,
just food for thought
Nov 19, 2011. 10:10 AMjspencer17 says:
How many melts did you end up getting out of your refractory mix? How about the second forge that you constructed and posted more recently?
Sep 9, 2011. 3:13 AMlpdunwell says:
awesome instructable!!
only one thing that could remove confusion: add something to the images to compare size, like a pet bottle or so. i thought this thing was tiny, but obviously it's not XD
Sep 5, 2011. 8:11 PMtincanz says:
Great instructable, but I wonder: what will you do with the ingot? will you make it into something useful i.e. a nutcracker :-), or will you just have it lying around? If you make things, you should do an instructable for it.
Jul 2, 2011. 8:41 AMjbend says:
can you use wood insted of charcoal.
Sep 5, 2011. 8:06 PMtincanz says:
I don't know about Aluminum, but for Iron, wood isn't hot enough. Its easy to make charcoal, though. just heat up wood in a container (maybe a can) over a fire. With the right temperature, the volatile gasses leave the wood without igniting, and the wood blackens, becoming charcoal.
Jun 4, 2011. 6:34 PM_Scratch_ says:
How many nutcrackers do you have??
Mar 24, 2011. 7:31 PMLambskin says:
Can you melt copper with it?
Dec 31, 2010. 10:52 AMg.petinati says:
Regular portland cement takes almost a month to cure completely. Refractory cement cures at a considerably shorter time, but let it cure for the time indicated on the package (or at least a week) before you remove the frame. This may prevent the concrete from cracking.
After 2 or 3 hours from the pouring of the concrete, put a damp cloth over the top of the furnace. Keep it wet the whole time and protect it from wind, wich will dry the concrete. If the concrete dries it'll be a lot weaker.
Congrats for the great instructable.
Oct 13, 2010. 7:31 AMundinstructable says:
Nice instructable, paracord!
I'd like to make you notice though, that you are not in the SAFE side!
You should operate on a bed of dry sand, not in proximity of a wood house
and on a not so dry soil.
If the melted metal drops to the soil it will instantaneously "explode" due to contact with moist/water on the soil and it would spray around spliters of melted metal.... mmmhh, I guess you dont want that!
I'm sure you have read suggestions and advices in
http://www.backyardmetalcasting.com/
Be careful.
Aug 15, 2010. 3:43 AMdidgitalpunk says:
very nice instructables! i started making a forge about threedays ago the crucible i made is a 5mm steel oxygen bottle an the forge itself is an old propane bottle( the one i used is about 50cm in diameter)
Aug 15, 2010. 12:52 PMdidgitalpunk says:
thanks for the tips! yhea i'll try to post some videos of what i did but it'll take about two weeks but i wont forget! thank again!
Aug 15, 2010. 3:55 AMdidgitalpunk says:
ho yeah i forgot. if you put aluminum with paint on it, does the paint burn and desintegrates or does it form slag? thnksfor answering!
Jul 30, 2010. 10:15 PMJimmy Proton says:
i made one similar to this it it gor hot enough to melt salt and glass and even small amounts of steel
Jul 16, 2010. 11:26 AMabraxsis says:
FYI, mixing black furnace adhesive/caulking with pearlite (a soil additive) is an EXCELLENT refractory material, not to mention very cheap. I used this inside a large coffee can for a small foundry when I work with larger quantities of silver than my blowtorch/ceramic crucible can handle. After a few partial fires (im big on tempering any refractory material at least 4 times before bring it to full temp) I was able to bring a coffee can foundry to a point I could melt small amounts of copper, which melt. closer to 2000 deg. F. Also, something to mention. NEVER ... EVER ... get molten metal on concrete (like in a driveway/basement/etc, the higher moisture content can cause a violent steam explosion which throws concrete shrapnel everywhere. ALWAYS try to use your foundry on the ground or use something like old drywall (the gypsum it is made from is nearly heat proof) as a "floor" under your melting/pouring location.
Jul 8, 2010. 8:23 AMblkhawk says:
Have you found any practical use for molten aluminum ? Do you think that machine parts could be made melting aluminum this way?
Jul 4, 2010. 1:40 PMChainfire says:
what were the dimensions,and how refractory did you use?
May 31, 2010. 1:13 PMsnowluck2345 says:
 Would reinforcing the concrete with rebar or chicken wire possible help with the cracking? How good of an insulator is the concrete? Would Sakrete possible be a better material to make the forge out of than concrete? Its meant to be an insolator. Could it handle the high tempatures? Also, not fully related to this instructable, just a question about firebricks. If you used the insolator firebricks, could you cover them with tiles, like leftover bathroom tiles, because apparently insulating firebrick is very soft, would the tiles be able to take the heat or would they crack?
Jun 26, 2010. 2:31 PMFred82664 says:
Try clay and Iron Oxide mix bake it with a small fire before using the blower and try a melt
Jun 8, 2010. 4:25 PMmagickaldan says:
Tiles will crack if you get them hot enough. fireplace mortar maybe? Or use some of the homemade refractory recipes on the net. http://www.backyardmetalcasting.com
May 31, 2010. 2:22 PMx z i t says:
i made an ingot before but completly out of soda cans. you just need to remove the paint from the melted aluminum with a fork
Jun 26, 2010. 2:23 PMFred82664 says:
it takes about two cases of cans witch is 48 cans to get a little over a pound good aluminum. I done foundry work for 15 years of my life. by the way aluminum melt down at 1500 Deg and is pored around 1550 to 1600 Deg depending on the casting being made.
Jun 5, 2010. 11:31 AMjoel383 says:
it's really not a big deal if you are just learning and pouring ingots. just remember to scoop the slag off last, not continuously.
Jun 26, 2010. 1:53 PMFred82664 says:
this is a good way to melt down a lot of beer and pop cans or hard drive bodies and platers
Jun 24, 2010. 9:02 AMcoppeis says:
Yes but what else can you make with aluminum?
Jun 17, 2010. 11:29 AMgreenfreak says:
dude! this is great!.... im gunna build one when i get some more cement! and im gunna use a metal box to keep it more sturdy!... thanks so much for the instructable!
Jun 19, 2010. 4:56 AMgreenfreak says:
alright man! will do...
Jun 13, 2010. 7:38 AMzcshiner says:
I have seen other furnaces put the blow pipe on the side of the wall vs the center, so it swirls the air (cyclone) instead of just pushing it inside. Think of a squirrel-cage blower, and where the nozzle on that is placed.
Jun 11, 2010. 5:29 PMld2i says:
Very well written, one of the best furnace/forge articles I've read. I'll be sure to try this once I get my hands on some materials. I have a couple of questions though if you would be so kind: Is it possible to use normal cement, or does it have to be the special refectory cement? And also, would this work to melt aluminum cans as well, or would those just disintegrate?
Jun 13, 2010. 7:24 AMld2i says:
Ah, I see. I'll look into that then. Thanks for the help, I appreciate it.
1-40 of 49next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
133
Author:NutandBolt(FLAMING FURNACE)
I have too many hobbies and never enough time. My blogs: Paracord projects: www.paracord-projects.blogspot.com- Metal Casting: www.flamingfurnace.com
