Step 11This was a fun experiment !!! Some conclusions
I don't recommend using tin cans at all, it can be dangerous, I got a few ingots out of it but one corn can I used broke inside the furnace with big holes.
This was a great experiment for first time aluminium casting.
Hope you enjoyed my instructable.
This is a short video I made, I know its not great and my hand is in the way and a bit of slag fell into the muffin tray but it gives the general idea of ingot making.
i am sure i read somewhere that if the inner refactory mix is not to thick, and then surounded by a layer of sand (allows expansion) or probably ceramic wool, then a further layer of refactory insutation, then a expandable layer (you get the onion ring effect idea) then the refactory layers are allowed to expand and contract without too much stress and therefore cracking. i think some experimentation is needed.
to hold the solid layers together(at the top), some wire netting, or stainless steel wire in a zig zag fashion around the circumference (binding)between the layers would bind the whole lot together, whilst allowing expansion,
just food for thought
You can place the cement in some metal container, the container will probably prolong the furnace life. You can google furnace refractory mix and you will see many sites that provide guides for the proper materials and mix ratio.
Most people start by melting cans the only thing is you need a lot of cans to get some decent amount of molten aluminium. And the cans produce alot of slag that have to be removed.
I would recommend melting some aluminium objects that you have no use for they will give you more molten aluminium.
