Mini Coilgun
10,032
17
25
Posted
Introduction: Mini Coilgun
this is my mini coilgun
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
25 Comments
how do i wind the coil e.g.
===== (barrel)
           <- one layer this way
one layer that way ->
etc.
thats why i wont work olny one way or your cross the magnetic feild
i made a coilgun with a bigger barrel and overall structure. i notice that when i charge for a minute nd a half, it does fine but very weak.when i go longer, it just sort of jiggles in the barrel. help? o i used two different gauges of wire connected in the middle of the coil (youll see) ill put up some pics...........
The neeter u wind the coil the better, wind it in only one direction too. when u get to the end run it streight back and start on the next layer, that will give u the best magnetic feild
so closeup you can see the different gauges of wire and sorta see my circut setup.... the metal rod is ammo
Hello guys
I am making a coilgun made of a disposable camera and some capacitors.
I have made a drawing with google sketch-up. Could you please check if I have made all the connections right? ( I am not an expert ……… yet)
www.elektronica_stuff.webklik.nl/page/voorpagina
please reply!
but when making the coil. does the wire need to be insulated so that they don't touch each other. otherwise it will be just like a metal tube
why didnt you just put a battery in the area where it is empty and if you have enough room put another extra batterey for if the other one runs out
