Mini Counter
2,416
14
30
Posted in TechnologyElectronics
Introduction: Mini Counter
About: I'm engineer and like to design electronic and programming things with Arduino hardware.
Mini Counter, it's a project that is based on an IC 4026 counter and a mini common cathode 7-segment LED display, and with help of a few components you can construct this interesting device. Next, go to the follow website:
https://www.youtube.com/watch?v=wUPSM8o28uE&feature=youtu.be
Step 1: Bill of Materials
1 170 Point 1 Terminal Strip Breadboard
1 Displays Segmented Module 1DIGIT 8LED Hi-Eff. Red CC 10-Pin DIP Tube
1 Capacitor Radial 10 uF 25v 20% 85c 4x5x1.5mm
1 DECADE COUNTER/DIVIDER DIP-16 (IC 4026)
1 Standard Timer Single 8-Pin Plastic Dip Rail (IC 555)
1 Resistor Carbon Film 1k Ohm 1/4 Watt 5% (In Bags of 10 and 100)
1 POTENTIOMETER,100K OHM,3362P-104LF,SINGLE TURN,.5 WATT,CERMET
What you will need:
Wire strippers and cutter
Needle nose pliers
Wire for connections
Step 2: Showing the Diagram
Follow carefully this diagram so that you can construct your project successfully.
Step 3: Installing the Main Components
In this step, you are going to install the mini common cathode LED display, the IC 4026, and the IC 555 timer in your mini breadboard.
Step 4: Mini LED Display Pins
The mini LED display is a common cathode LED display 7-segment and its distribution of pins is showed in the picture attaches in this step whose numeration forms an inverse "U" from 1 to 10 pin of this component.
Step 5: Connecting the LED Display Pins
In this step, I am utilizing a color of wire only. For that, you need to observe carefully the diagram in step #2 to identify the LED display pins and their right connections.
Step 6: Connecting to +5V
In this step, you are going to connect to +5V by using the same color in this case: red.
Step 7: Connecting to GND
In this step, you are going to connect to GND. Note that I am utilizing the following colors: orange, brown, and metallic. It's so that you are following the diagram of your project.
Step 8: Connecting the Capacitor
In this step, you are going to connect the capacitor and doing a connection between the two integrated circuit by utilizing a yellow wire.
Step 9: Installing the Potentiometer
In this step, you are going to install the potentiometer
Step 10: Connecting the Resistor of 1K
Connect the resistor of 1K and do the last connection by utilizing yellow wire. It's imperative that the diagram be followed carefully so that you end correctly your project.
Step 11: Probing the Project
Probe the project and check each connection that you did so that your project functions correctly.
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    30 Comments
    LEATHERWORKING classes are now free in this site.
    PHOTOGRAPHY classes are now free in this site.
    BREAD classes are now free in this site.
    CANNING PRESERVING classes are now free in this site.
    WOODWORKING classes are now free in this site.
    GLUE classes are now free in this site.
    CONCRETE classes are now free in this site.
    MEAT classes are now free in this site.
    WEARABLE ELECTRONICS classes are now free in this site.
    RASPBERRY PI classes are now free in this site.
    LASER CUTTING classes are now free in this site.
    LAMPS classes are now free in this site.
    CNC classes are now free in this site.
    3D PRINTING classes are now free in this site.
    Robots classes are now free in this site.
    Electronic classes are now free in this site.
    Arduino classes are now free in this site.
    LEDS & LIGHTING classes are now free in this site.
    You can make more electronic projects with Instructables classes because electronic class is free.
    Doing tiny projects is always funny.
