Mini CrossBow ( Verry Powerfull)
956
Published
Introduction: Mini CrossBow ( Verry Powerfull)
THANKS TO dragonego   I modded a bit ^^
Shoot Red rods shown in last step
movie will come later
shoots around 40ft +
IMPORTAND! dont shoot on heads of people or animals ( my friend had 1 to his head he said it hurts verry much O,o )
u can put maney as rubber bands on it as u like and it can hold ^^
sorry for bad english
Step 1: The Stock
 put nice muzic on
1)make this
2)attatch the white rod as shown
3)put white rods like i did
4)Put 3 red on
5)put the bleu on and twist it like mine
6)put under the gray and up the green as shown
7)add the blue as shown
8-9) u should have this now
Step 2: Trigger Meganism
1) make this
2) slide a blue rod inside as shown
3) add 1orange conector at each side LOOK GOOD IF U DONT IT WILL NOT SHOOT!
4) side few of (3)
5) put at each side a bleu ring and a brown or gray conector + put a orange con as shown
6)make this
7) put it on like this PUT IT ON THE GOOD SIDE! OR IT WILL JAM !
8) conect it to the stock like this
Step 3: The Front
1) make this
2) Add the reds as shown
3) add a GRAY rod like this
4)make this its not hard so i didnt take picts of it con for con xD
5)attch 2 yellow rods as shown held together with orange con and put 1 bleu rod as shown
6) make this
7) put what u made by (6  on like this
8) attch it like this to the trigger and stock
Step 4: Finishing Touch
1) this is the bullet
2) add rubber bands for putting the trigger back in place  ( both sides the same amount of bands)
3) fireing bands put on as shown
4-5) loaded
pull back the orange con (fast and hard pull back) and it will shoot nice and hard ^^
    • Stick It! Contest
      Stick It! Contest
    • Planter Challenge
      Planter Challenge
    • Casting Contest
      Casting Contest
    7 Comments
    By the way, your English is not that bad. :)
    Awesome! I don't quite have enough pieces. Will buy though. Anybody feeling genorous?
    5* omdat je nederlander bent ;)
    meh...
    Dude, this is WORSE than those block trigger guns that spam Instructables, mostly because it uses an outdated mechanism on something that's BARELY a wireframe.
    It's using a crude variant of a mechanism that's been posted a LOT of times on MUCH better guns. Also, it's called a HANDLE, not a stock.
