Mini Crossbow
Introduction: Mini Crossbow
Hello people! In this instructable I will show you how to make a mini crossbow. Of course streaking burning matches at your own risk!
Step 1: Things You Need
You need:
  • 2 popsicle sticks
  • rubber band
  • bottle cap
  • Matches
  • Hot glue gun
  • Soldering iron
  • Nippers
  • Marker
Step 2: Preparing the Bottle Cap
Draw a cross on the bottle cap. Mark on each end of the cross 1 centimeter on the side of the bottle cap. Seen from above, the upper and lower approximately 3 millimeters from the top, the left and right 5 millimeters from the upper edge.
Use the soldering iron to open the markings on the sides. These are about 11 millimeters wide.
Step 3: Fitting the Cross
Push the popsicle sticks now through the holes in the bottle cap. Glue them with hot glue.
Step 4: Hole for Projectile
Make a hole (2 mm) in the front and back of the cap with the soldering iron.
Step 5: Assemble the Rubber Band
Make a small indentation on the left and right of the popsicle stick with the nippers. Put the rubber band around it and put him behind the bottle cap.
Step 6: Ready!
Ready! Great shooting fun !!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Trash to Treasure
    Trash to Treasure
  • Pro Tips Challenge
    Pro Tips Challenge
This is an exact copy of DaveHax's design.
Checked and it is not. It is similar in design, however this one uses a different way of spanning the rubber band resembling a bit more like a crossbow.
It's not a copy! Thank you.
