this is my first instructuble and i want it to be great
Here is the MiNi Airconditioner ideal for desktop usage
and only with a burger box smalleness!!
gogo try one now and a Mini aircon is all yours
Remove these ads by
Signing UpStep 1What You Need
.Burger styrofoam box
.A small exhaust pc brushless DC fan the thicker the width the better!!thin fans wont have mush airflow thicker ones better!
.Some mounting tape
.Multi purpose glue
.A huge big pc heatsink> longer fins...better
.Or and alternative to the heatsink is cutted out in can into rectangular shape with holes in it will do
.Power for the fan itself(self-known)
.Lots of ice
all these totalled up to be less then $5USD
why do we need a heat sink ?? & how effective is it ?
This system may be made more efficient by placing the larger part of the heatsink in the water instead of the fins. This would increase the surface area that is coming in contact with the air and more quickly remove the energy from it. Because of how thick the base of the heatsink is, it is going to take longer for it to cool than the fins and will store some heat inside it. Because it takes longer to heat the water than the heatsink it is okay to store some of that heat so that it may be dispersed at a rate that the water is able to agree with. It's better to store heat in the base than to try to force it to absorb the heat from the air.
This should make the air coming out of the unit cooler but it will also mean that you will need to replace the water more frequently because the speed at which the energy flows will be increased.
