Step 5About the firmware and supercap backup
The firmware initialises io, then reads the every ten seconds or so (you can modify this in the code if you want a quicker update or random update times. I found this period to be the least distracting). If keypresses are detected then it goes into the clock time change routine until exited with a press of switch one.
Also in the design is a space for a supercap. I haven't tested this, but installing one should allow the clock to handle power outages for a short period of time.
In the firmware once the RTC data is read, a routine takes the digit values and assigns a random selection of active LEDs to that digit, the same number as the digit value. These are kept in a table. An interrupt routine takes one value out of the table at a time and sends them to the LED driver chips, and an LED is lit (actually two, one per chip). Next entry to the routine gets another and so on. When run fast enough the LEDs active in the table all appear to be lit at the same time. You can change the timing of the interrupt routine to make it faster if you like.
Have fun, and if you build one of these into something cool...send me a picture.
Philip Pulle
www.rgbsunset.com
Add Comment
