Introduction: Mini Dry-Ice Fog Machine
Picture of Mini Dry-Ice Fog Machine
Are you about to have a party? Need to setup some props for Halloween? About to put on a play at the local school or church? Then you my friend need a Dry-Ice powered Mini Fog Machine!
And I'm going to show you how to make one for less than $10.
Step 1: Watch the Video!
Even though this is a simple project, it's really helpful to watch our video. So take a second to do that, and then head on over to Step 2!
Step 2: Items Needed
Picture of Items Needed
You're going to to need to following items to complete your Mini-Fog Machine. You can get them all at your local big box store.
  • Small plastic container
  • 2.5" PVC Adapter
  • 2.5" PVC Pipe, 6" long
  • Computer Fan
  • 9V Battery Snap
  • 9V Battery
Note on sizes: You can make your Mini-Fog machine bigger by buying bigger components. A trash can and a box fan would make a huge fog machine for example. All you'd need then is more dry ice and more water.
Step 3: Cut Out the Holes
Picture of Cut Out the Holes
You'll need to cut two holes in the mini-fog machine's plastic container.
Cut the first hole in the top (the lid). Make it slightly smaller than the computer fan you purchased. Cut the second hole in the side of the plastic container. This hole will be where we thread the PVC fitting into. Make this hole smaller than the threads so that they will screw into the hole and seal it when done. Just 1/32" to 1/16" smaller should be plenty.
I used masking tape to cover the lid and sides of my mini fog machine. This allowed me to mark on the tape and then remove it when done, leaving no markings on the finished product.
You can cut the holes with anything from a razor knife or sharp scissors to a rotary tool or hole saw. I chose the rotary tool with hole cutting attachment, because I already had one.
Step 4: Attach the Fan and Outlet Pipe
Picture of Attach the Fan and Outlet Pipe
Use hot glue, or CA glue ("super" glue) to glue the fan to the lid. CA glue won't hold up to moisture rich environments as long a hot glue, but it should do the job. If you bought a square computer fan, you can just use some screws and the four screw holes provided.
Screw the outlet pipe into the hole you created earlier on the side of the container. No glue is needed, but you could use some hot glue if you desire.
Once that's complete, attach the 9V battery to the 9V battery snap and twist the wires together from the snap to the fan. Red to red, black to black. If there are four wires on your fan, only use the red and black. The other two are speed controllers and not needed for this project.
Step 5: Boil a Few Cups of Water
Picture of Boil a Few Cups of Water
Boil a few cups of water in the microwave. Generally 3 minutes or so.
Step 6: Add the Water and Some Dry-Ice
Picture of Add the Water and Some Dry-Ice
Pour the boiling water into the Mini-Fog Machine's container. Be very careful not to spill it as it will of course burn you badly.
Carefully, using gloves, break of some dry-ice and gently place it into the boiling water. Do NOT drop it in the water as it will splash boiling water out!
Place the lid back onto the container with the fan running,
Step 7: Enjoy the Fog!
Picture of Enjoy the Fog!
That's it! You're mini fog machine should be making a ton of fog! Place it on the stage or behind your Halloween decorations and let the fog cover the area!
If you liked this project, you'll probably like my other projects too! So be sure to check me out here on Instructables, on my website at The Geek Pub, and over on YouTube at YouTube.com/c/TheGeekPub.
Ardutronico (author)2015-12-30
I'll probably make it, and add some improvements, like an automated dry ice dispenser.
SwiperF (author)2015-10-15
I saw a video when you put small pieces of dry ice (about 1 lb / half kilo) in a bucket of very hot/boiling water.
Instantly, your floor disappeared underneath the fog about a foot high (and probably higher in enclosed spaces.
ippy1967 (author)2015-09-22
Hi, can you tell me how long the fog effect lasted before the water cooled to much to make a decent cloud?
RonW13 (author)2015-09-19
Not sure what big box you are referring to, but I cannot find the fan or 9-volt battery snap at any big box retailer.
mikem5906 (author)RonW132015-09-20
You can get them both at Fry's or Best Buy.
RonW13 (author)mikem59062015-09-20
How were you able to complete the entire project for $10.00? The cheapest fan at best buy I can find is $15.00. And the only fans they carry are 12v, not 9v. Running a 12v fan on a 9v battery will burn up the battery in minutes will it not?
TheGeekPub (author)RonW132015-09-21
I got my fan for less than $5. All computer fans run at 12v. That's not how this works at all. A 12v fan running on a 9v battery will run just fine. It will run at 75% of its rated speed, but other than that function 100% normally. In other words a 2000 RPM fan will run at 1500 RPM, which is more than enough for this project. In fact, some people have modified my project with a potentiometer to slow the fan down even more.
SisterDharmaG (author)2015-09-15
I am so excited by this idea! Thanks so much for creating this tutorial! Do you have any suggestions on how one could make a portable or wearable version of this device? I will be part of a creative fashion show in a couple months and the theme is "7x7" in reference to the show's 7 year anniversary and San Francisco, where it originated. My vision for my outfit includes a tribute to "Carl the Fog" (yes, SF's fog is named Carl --- and even has a Twitter account). I'd love to be able to make a tiny, yet dramatically powerful version to conceal under my dress so as I walk it looks like I'm floating on clouds, or something. Thanks again!
marshabarton (author)2015-09-11
Love the idea...but I'm not a "geek" so I have no clue how to power the PC fan with a battery. Can you enlighten me?
2build (author)marshabarton2015-09-11
Normal fans operate at 12V, so you can take a 9V battery and connect the red cable to the positive pole and the black to the negative, that's all
marshabarton (author)2build2015-09-14
Great! Thanks so much for your help...I'd like to try this for Halloween. We have an office decorating contest at my work and I'm hoping this will work better than the full-size fog machine I already have. It works too well for a small office space and the fog juice has a smell to it that might not be appreciated by my coworkers. THANKS AGAIN!
AymanB1 (author)2015-09-13
comment préparer un glace sèche
merci
lilababiuk (author)2015-09-10
OMG! Totally loved the project, but I`m really in love by your cutting machine! what's the name? I live in Brazil, and never saw one of those! I'm a student of architecture and I'm always using saw machines to do my 3D models! one of those would be AWESOME for me! hahaha
TheGeekPub (author)lilababiuk2015-09-12
It's called an X-Carve by Inventables.
DanielR68 (author)lilababiuk2015-09-10
eBay and Amazon have ROTARY TOOLS W FLEXSHAFT available for $25.
Kinnishian (author)lilababiuk2015-09-10
Looks like a dremel tool with a router bit and a router attachment. You probably have if not dremel tools available, alternative "rotary tool" that will work.
The router bit can be a little tricky to find though, because these tools are more often used for cut-off discs, polishing, and grinding. Using a router bit is less common and not as well known.
metqa (author)2015-09-10
Neat Ible. Since CO2 gas is heavier than air, you are likely also safe unless you lie down on the floor in a pool of in and start taking gaping breaths of it. Anyone standing above the fog will be breathing safely. One way people try to intensify the effect is by erecting floor level barriers to contain the CO2 gas, making the floor space actually fill with flooded gas. otherwise it spills to the lowest point and eventually blends with the air. I've often wondered if plants would benefit from a fog of CO2? If you have some potted houseplants, you could make an interesting scene by using the pots to hold the fog barriers up and the mist would flow around the leaves and make it look spooky, misty and foresty. Again, thanks for the simple ible!
TheGeekPub (author)metqa2015-09-12
You could make a "plant fogger" and get rich!
One80Bits (author)2015-09-11
that is awesome!!! where does one obtain dry ice though?!
cattrouble (author)2015-09-10
How long does it last?
cosmicslop (author)2015-09-08
So simple, you don't even need any fancy gear - anyone can get their hands on a computer fan and a PVC pipe. I'd totally consider it for my next party (or just for my own personal entertainment lol) but.. can someone assure me that the carbon dioxide is completely harmless as long as you don't breathe in too much of it? I'm pretty sure it should be
TheGeekPub (author)cosmicslop2015-09-09
Humans inhale oxygen and exhale carbon dioxide. You're breathing it all the time. The problem only becomes when there is so much carbon dioxide that no oxygen can get into your lungs. This is very unlikely to happen with this tiny device. Imagine 500 people in a room inhaling the oxygen and exhaling CO2. Does that scare you? No because it happens all the time. This puts out much less than 500 people. Just don't use it in your closet. :-)
aisaacs3 (author)2015-09-05
You're probably right. I should have preference my comment with that I do not know what amount it would take to be dangerous or the O2 displacement rate per cubic foot. I have used dry ice myself at my kids birthday parties. still cool nonetheless.
TheGeekPub (author)aisaacs32015-09-07
Yep. Safer is always better!
This is an awesome idea and would be fun when used properly. The firemen in me is compelled to add this though.
Dry ice is nothing more than a solid form of carbon dioxide. Instead of melting into a puddle of liquid carbon dioxide, it sublimates directly in to carbon dioxide gas. Carbon dioxide gas can be very dangerous when you are in a confined space. Dry ice rule #1 is that you must use dry ice in a well ventilated area. As dry ice warms up, it releases carbon dioxide gas in to the air. Too much carbon dioxide gas can cause asphyxiation and even death. Always use dry ice in a well ventilated area.
TheGeekPub (author)aisaacs32015-09-05
Thanks for the comment. We are talking about incredibly small amounts of dry ice in this case. To run this machine for 30 minute equates to the exhales of about 5 humans over the same time frame. That's quite safe.
However, should someone ramp this up to a 30 gallon trash can and fill it up with dry ice, you're absolutely right. You need to be outside.
wannabemadsci (author)TheGeekPub2015-09-06
Our bodies are pretty smart. As the carbon dioxide level increased your respiration rate will also increase to try to compensate - So if you start breathing faster, and not from increased exertion, then you had better get out or ventilate the area. I've had this happen and it is quite apparent that there is too much dry ice fog around. Better to keep it well ventilated than to find out in this manner, though.
sgy69 (author)2015-09-05
Fantastic for Halloween outside as the other half wants fog in the grave yard I will haveto make this thanks for the great idea and pictures.
erdalbozok (author)2015-09-05
party time!
TheGeekPub (author)erdalbozok2015-09-05
"Party on Dude!"
About This Instructable
36,344views
523favorites
License:
Bio: I'm Mike, from The Geek Pub. I'm a maker. I love to make things. from woodworking to electronics. Follow along with me!
More by TheGeekPub:The Brain of MorbiusMinion-O-LanternsNinja Star
Add instructable to:
