Mini Engineers Square From Steel Angle
2,627
31
Published
Introduction: Mini Engineers Square From Steel Angle
Make your own Mini engineers square from steel angle,
Using a hacksaw angle grinder or metal cut of saw you can make your own engineers square with just 3 cuts. Your cuts don't even have to be strait as the critical edge is the inside face of the angle
Video here
Step 1: Cutting..
Use a hacksaw, angle grinder or cut off saw to cut down one side of a piece of steel angle then cut the whole section off as show in the images.
Step 2: Making the Blade and Finishing It.
To make the blade I cut one part of with a hacksaw then filed the stock down then I took it over to the oil stone and cleaned everything up.
Be safe and have fun !
Check out my video here
    • Creative Misuse Contest
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
    2 Discussions
    You can use metal shelf brackets as squares. Just make sure they are square, with a real square before!
    This is brilliant.
