3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Mini electronic detonator
This inscrutable will show you how to make a simple yet effective electronic ignition system.
BTW, first instructable! :)
For this instructable you will need:
1. Switch.
2. Push Button (I ONLY HAD TWO SWITCHES)
3. LED (don't have one... find an old computer and take out the HDD light or the power light)
4. 9v Battery.
5. 9v Battery Connector.
6. Soldering Iron.
7. Multimeter (very helpful if using the headphone jack version)
8. Small box to put it all in.
9. Wire, lots of wire.
10. 1K resistor, to stop LED from burning out
OPTIONAL
0. 3.5mm Jack (take from mp3 player or other)
0. Cheap Headphones
0. Steel wool to test that it all works :)
0. Hot glue gun (also not needed, but helpful)
Step 1Collect all the stuff.
This is the general set-up you will be using.
As you can see in the picture once the ARM switch has been flipped the LED will come on showing that there is power going through the circuit.
When the FIRE button / switch is pressed the power is sent through the jack or just wires to steel wool. steel wool is very fine and will glow red hot when a current is passed through it.
16 comments
Sep 5, 2011. 6:24 AMPyroWork says:
is it okay if i use alligator clips at the end of the wires??
Mar 13, 2011. 7:24 AMaashilrv says:
I've done it finally.Works fine too thanks
Mar 10, 2011. 9:24 AMaashilrv says:
I am definitely gonna make for my match rockets.
Jan 9, 2011. 6:05 PMingloriouspyro says:
the arm switch should have a cover over it. but other than that the thing looks awesome.
Dec 6, 2010. 8:10 AMcelticrush97 says:
Is the steel wool needed or optional to use it?
Dec 9, 2010. 12:49 PMcelticrush97 says:
what about the 1k resistor? and wheir can you get it from?
Nov 16, 2010. 3:04 AMBSN4_N says:
why is it my steel wool doesn't burn ? pls answer my question thanks.
Apr 18, 2010. 2:40 PMyurifreitas says:
I don't know a lot of electronics, but adding a capacitor wouldn't make a higher discharge that improves the efficiency of the ignition? If so, what capacitor would fit the best? (If I made mistakes, please correct me ASAP!)
Apr 17, 2010. 11:32 AMPurple Guy says:
 Nice design! I'm gonna have a go at making this once I collect all the materials together, I'll upload a photo of it once I'm finished :D
*Purple Guy*
Jan 1, 2010. 3:43 PMchris-boeitniet says:
great instructable :D
it would be a perfect combination if u used http://www.instructables.com/id/How-to-Make-Electric-Igniters-from-Christmas-Light/ :D
Jun 28, 2009. 2:28 PMcaco caco says:
i would try it
Jun 26, 2009. 9:20 PMProud American Pyro says:
Well you can just use a model rocket ignitor and it works fine.
May 25, 2009. 3:40 PMedfel01 says:
were does fuse go?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Davidnipp
