Introduction: Mini Fog Maker
This is a mini fog maker that I saw on a website and thought I could improve.
Tools you will need:
a Philips screw driver
a Hot glue gun
sizers
a Sharpie
and a knife.
Things you will need:
a Coffee tin
dead 9v Battery
new 9v Battery
Dry ice
and a old computer.
Step 1: Find a Old Desktop.
Open up the computer and find the fan,
unscrew it with your philips and free it from the computer.
Step 2: Find the - & +
Cut the end off of the wire and pull the rubber off the wire close to the end.
Then find out which wire is - & + by setting a wire on the + of the battery and a different wire on the -. Hint(The black is always -)
Then cut the other wires off.
Step 3: Coffee Tin
Grab your Coffee tin and pull the lid off.
Then set your fan on the lid and trace it with your sharpie.
Cut the hole a bit smaller than you traced and hot glue your fan pointed down.
Step 4: Old Battery
Cut the case off of your OLD battery and rip the plugs off.
Take the negative wire and hot glue it to the positive lead,
and vise-versa.
Step 5: Put Something Round O
Put something round on it and cut it with a knife.
Step 6: Water & Dry Ice
Put a cup of hot water in it and some dry ice,
then turn it on and enjoy!
Microcontroller Contest
Tech Contest
DIY University Contest
