3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Mini Fridge
Mini Fridge
So this guy at work got a neat little mini fridge for a can of coke. I thought to myself "I can make one better than that". And so my home made mini fridge was born. It has 3 peltier coolers enclosed is a 4 inch diameter pvc T joint. It's powered (underpowered by about 120 watts) by a 55 watt 5 volt power supply. The power supply was only $6.00 and I couldn't find one more powerful that fit my specifications and was relatively cheap. It cooled the inside down to 68 F when it was 96 F outside. I took it inside and it cooled down to 46 F. Unfortunately I didn't think to make an Instructable until afterwards. I haven't actually made an instructable yet but I think I've got a good one brewing. In the mean time, here are some picture.
54 comments
1-40 of 54next »
Jul 28, 2011. 6:43 PMnsmf says:
i have a question, i basically have very little knowledge in electronics. Will it be a problem to have a power supply lower/higher Amps than my peltier? what if I have 2 or more peltier and power it up straight to the power supply will it equaly have the same voltage, or i have to do extra wiring for multiple peltier?
Aug 1, 2011. 2:45 PMmr. clean says:
actually ive found that using a computer power supply is the best because the computer supply wont force in more current than the peltier can handle, i use a 430 watt supply with a 168 watt peltier and it works perfectly
Aug 2, 2011. 8:02 PMmr. clean says:
yes ive measured the amperage and it is only pulling about 8 amps at 12 volts, and i am only using one 12v rails out of 2.
the TEC specs are Vmax 15.4v Imax 11A resistance 1.16 ohm.
Do u have any ideas on how get the TEC to use full amperage, because if i am correct then the TEC should use 14 amps at 12 volts.
Aug 4, 2011. 9:12 PMmr. clean says:
yes I think you may be right as one 12 volt rail offers 14 amps and the other offers about 16 amps. so it is most likely the supply that is limiting the amperage. Do you think it may be possible to link the two 12 volt rails in parallel for more power delivery or would i risk frying the power supply?
Nov 11, 2010. 6:48 PMreddog92396 says:
Alright... I just have a few questions, How many peltiers would you recommend for a 2 liter soda bottle holder? How is it in a not so well ventilated space? How long do you keep it on, how many hours (or none) straight? Thanks
Nov 20, 2010. 3:51 PMreddog92396 says:
Also I almost forgot to ask where you got your power supply? Thanks again
Nov 25, 2010. 7:16 AMreddog92396 says:
Thank you so much, I can't wait to start this project, Happy Thanksgiving by the way (unless you're not from the US).
Nov 18, 2010. 12:50 PMreddog92396 says:
Thanks so much, sorry I didn't see that you replied right away. Wow 24 hours sounds great! though....it looked.....questionable haha thanks for the info though.
Nov 11, 2010. 6:50 PMreddog92396 says:
The only reason I ask about the ventilation question is because when one side of the peltier gets cold, one side gets hot, so basically how well did your heatsinks or fans do for the hot side? Once again thank you very much
Aug 16, 2010. 7:34 PMThe1PublicEnemy says:
where do you get a peltier thermoelectric module?
Sep 15, 2010. 3:45 AMwww.bkbelectronics.com says:
http://www.bkbelectronics.com/peltier%20cooler.html
Jul 22, 2010. 1:52 PMedfel01 says:
Please make an instructables there's nothing on how to make a mini fridge like this and it's looks like the best I've seen by far
Aug 25, 2009. 11:40 PMrackne says:
to improve WMD look&feel I suggest red LED display counting down time to reach desired temperature. It may also beep every second ;)
May 8, 2010. 10:23 PMoakironworker says:
That was funny my friend
Aug 29, 2009. 8:05 AMdagenius says:
yah, but when you are just passing through customs, and they see a pipe device counting down, you are not going to last very long...
Aug 26, 2009. 1:36 PMcovey12 says:
with a hear pounding in the back ground like 24 lol
Oct 23, 2009. 1:03 PMfredrikher says:
realy good project;)
Sep 7, 2009. 11:35 AMH3xx says:
You could use an Igloo cooler lunchbox. It might look like a bigger bomb, but would be more efficient and have a handy carrying handle.
Sep 6, 2009. 1:53 PMGalforg says:
Haha, looks like a time machine.
Aug 26, 2009. 3:41 PMTechnochicken says:
Great project. I'm tempted to make one, stick a fan and a vent in it, and stick it in my computer case. An idea for an improvement would be to use an old ATX computer powersupply. Even the cheapest easily have over 20 amps on the 5 volt rail. This would make it slightly bulkier, but you could easily get sub freezing temps, and have a mini freezer if you wanted.
Aug 31, 2009. 6:51 AMdagenius says:
Yeah, but I would not want to risk putting 20 amps through one of these units. A 20 amp peltier unit could cost a fortune.
Aug 31, 2009. 6:46 AMdagenius says:
you could disassemble it, and then make an instructable...
Aug 27, 2009. 5:47 PMWhales says:
What nice comments revolve around in that weird community....
Aug 30, 2009. 7:44 PMshortwave says:
seriously I would consider this project for a water cooling system for my PC figure out a way to seal the pelter's to the PVC pipe and or get a 4 way pipe that size seal the pipes with caps and out fit the insides with a coil of copper and fill it with antifreeze and a small pump to circulate the fluid to each pelter heat sink THEN foam the pipe without blocking the pelter's heat output. know what look forward for me to add to this i got a good idea and i need 4 pelter's
Aug 28, 2009. 9:35 PMdmastachief says:
i bet if you got within sight of an airport with that you'd have bullet in your head before they would even try to stop you
Aug 28, 2009. 10:03 PMconrad2468 says:
ITS NOT A PIPE BOMB ITS NOT A PIPE BOMB!!!!! ha ha ha!!!
Aug 29, 2009. 12:52 PMdmastachief says:
to late BLAM!! and now your brains are on the ground
Aug 25, 2009. 12:03 PMAndyGadget says:
That is so way beyond ugly that it's GORGEOUS! Really not something to be seen carrying in public for all sorts of reasons. (How about adding a big red digital temperature readout?)
Aug 28, 2009. 12:49 PMcodongolev says:
you could possibly make a second enclosure out of metal or something... then put it around the pvc and add insulation.
Aug 28, 2009. 10:17 PMKT Gadget says:
The only issue with the pipe inside another enclosure is the heat. Since the air is pushing the hot air sideways, there needs to be another fan that can quickly exhaust the fan, which for 3 heat sinks putting out heat, it would need a powerful one or a bunch of strong ones. Other than that, the box would definitely look much better than a pipe with wires everywhere.
1-40 of 54next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
24
Author:CaptPikel
