Mini Knex Gun
1,148
Published
Introduction: Mini Knex Gun
About: Well I'm the kinda guy that doesnt bother with About Me's but if I must: -I do alot of model building and airbrushing -I try to make/do anything i think is cool -I'm currently in Grade 9
This is my first intructable so go easy on the comments plz. a simple yet effective gun. shoots black or white rods or paper rolls
Step 1: Collect Materials
look at the pic.
Step 2: Ramming Rod
connect orange connector to blue rod
Step 3: Barrel and Trigger
use 5 grey stoppers and 1 red triangle connector and put together by following pic.
Step 4: Trigger Cont.
add small green rod to the end of the red traingle follow pic.
Step 5: Putting It All Together
put the ramming rod thru the barrel . follow pic.
Step 6: Rubber Band
put the rubber band around the gun . follow pic.
Step 7: Shooting.
pull the ramming rod by the connector. it shoud click into place and the red traingle should jamm the rod follow pic. put the ammo in the barrel follow pic.to shoot push the green rod backwards. hold oit by the grey barrel or it will hurt your finger. shoot away!!!!!!!!
  • Oil Contest
    Oil Contest
  • Woodworking Contest
    Woodworking Contest
26 Comments
should i make instructions for this
https://www.instructables.com/id/Simple-And-Effective-Knex-Gun/
it doesn't require a lot of pieces and works really well!
it shoots ok but if you make a handle for it its a good pocket weapon
if you insert a snapper into the barrel then block it with tape or something it can be a starting pisol, but that can be said of a lot of guns.
it is also good for chain guns.
aww cmon this is my first instructable, i dont have good ideas
"first instructable" is not an excuse anymore. You could try looking at the good knex guns (go to explore>rating>knex), and get your inspiration off them.
it is my 1st, i only hav 2 instructables
read my comment above.
there is no reason to like it....
NOO MMOOOORRRREEEE of these dumb 11 piece knex guns! 0.5*
its not dumb good 4 shooting people w/out them noticing
