Introduction: Mini Lamp
Picture of Mini Lamp
This lamp is very easy to make.
Just follow the steps.
Step 1: Material
Picture of Material
Material
  • These small LEDs can buy on eBay.
    Blue circle serves as a mounting base for a lamp.
  • The green wire is the carrier of LEDs.
  • For this job you need about 10 minutes
Step 2: How to Make a Lamp
Picture of How to Make a Lamp
First you need to roll the wire as in the screenshot.
Subsequently on one end of the wire put a small LED.
And paste them on the wire.
Plus (+) and minus (-) of the LED diode connected to a wire, which will be after the merge of the 9v battery or 3V. When done, tape the other end of the wire to the blue circle, or something else that can be the base for a lamp.
Step 3: Finish!
Picture of Finish!
When all done, you can connect the battery.
Wire can bend and adjust as you want.
Leave a COMMENT and VOTE
audreyobscura (author)2014-05-19
Hey there, in which country are you located? The Lamps and Lighting Contest is only open to US residents.
Hello! I live in Bosnia and Herzegovina and the no contest can not put anything.
Can you send me a message when it's a contest for Bosnia and Herzegovina.
Akin Yildiz (author)2014-05-13
you can easily use another material as the arm and make it look more sleek... check it out..!
https://www.instructables.com/member/0bios0/?show=I...
About This Instructable
1,140views
15favorites
License:
More by alilovic007:Mini Lamp555 Timer Flashing LedHow to Build Slayer Exciter (mini Tesla Coil)
Add instructable to:
