Mini Miter Box
Published
Introduction: Mini Miter Box
Mini miter box for a 0.01 kerf razor saw.
Step 1: Cut Wood
Cut some MDF and wood to desired box length and width.
Step 2: Rout
Use a router to create a lip for the rails to sit on.
Step 3: Rails
Cut rails at 30, 45, and 90 degrees.
Step 4: Align
Line up the rail pieces so all desired angles fit the length of the box.
Step 5: Glue
Glue the rail pieces in place. Sandwich the saw between pieces to maintain the correct spacing. Use a square for the 90 degree angle.
Step 6: Cut
Put the box to use.
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    4 Comments
    One advantage a miter box has over a power miter saw is in cutting molding. Set up is faster and tear out doesn't need to be mitigated. Also, I'll be recruiting my wife to work on the molding. She would never use a saw that was plugged in but a handheld saw she'll weild.
    May i ask why do you need a Miter-Box if you have a Miter-Saw? (Other than the fact that someone that doesn't have one, could make this at a workshop...)
    You might want to saw a small kerf line into something like an instrument neck to add frets or you might have very small and delicate pieces that would be dangerous and cumbersome to cut with a large power miter saw.
