Step 4Prepare the Lexan touchsurface
To get the most light into the touch surface, one of the 8-inch edges of the Lexan touchsurface must be made very smooth (this is where the LEDs will make contact with the touchsurface). Ideally, you'll use three materials: 400 grit sandpaper, 800 grit sandpaper, and brass polish. If you don't have brass polish available, you can use just the 400 and 800 grit sandpaper, but the results will be less than spectacular.
Fold a piece of 400 grit sandpaper over a block of wood (or even a small paperback book), and run it back and forth three or four times along one 8-inch edge of the Lexan touchsurface. You should see small white flakes coming off. Repeat this with the 800 grit sandpaper. After each pass with the sandpaper, you should be able to see that the scratches and blemishes on the edge of the Lexan are growing smaller and smaller: this indicates that you're doing a proper job (and isn't that encouraging!). After sanding down the blemishes and bumps, polish the edge of the Lexan (only the edge!) using your brass polish (follow the instructions on the brass polish container).
Admire how smooth and shiny your Lexan edge has become.
comments
Add Comment
Add Comment
![Enable mouse and keyboard functionality on an iPod Touch or an iPhone! [Linux]](http://img.instructables.com/files/deriv/F09/VY6U/G9GQGXFB/F09VY6UG9GQGXFB.SQUARE.jpg)
