Mini-POV Hat
13,882
28
7
Published
Introduction: Mini-POV Hat
About: I love fixing and building things, just about as much as tearing things apart. It's kinda like working a puzzle. The only problem with building things, is that I get so into it that I don't take time to get ...
I took the schematic and theory of a MiniPOV2 and adapted it to make a hat for Halloween. It is basically the same circuit as a MiniPOV2 but with a few different components to make it fit the hat better. As usual, I never take the time to document things as I'm building them. I'm just too excited to get the project built. So what you'll see is a retrospect of what I did, and some changes in what I would do again.
Step 1: Items Needed
Parts these are what I used, but yours may vary depending on what you scrape up.
ATiny2313www.sparkfun.com
20 pin socket
8 LED's (I used the mini T1's, but probably just about any would work. Make sure they are all the same, I raided mine out of novelty toys and my junk bin and some are brighter than others)
8 100ohm resistors
2032 battery holder and battery
PC mount switch
Fine enameled wire like what is used in hobby motor coils. That is where I got mine, tore apart an old non-functioning motor
Stiff wire I used .025" music wire, but in hindsight I needed something bigger, like a thin clothes hanger
Heat shrink tubing or electrical tape this insulates the LED's from the wire, and contains all the thin wires together in a bundle.
Perf board about a 1-1/4" x 3" piece
5 pin header optional, but I don't have to pull the chip out to change signs
Small hobby motor I couldn't find any specs on the one Ii used (found it in my junk box of motors) I think it was originally meant to run on 6 or 12 volts, because at 3 volts it only pulled about 20mA, and runs fairly slow, which is good.
2 "AA" battery holder with switch, or separate switch
Tools
Soldering iron
solder
Hot glue gun
tweezers
pliers/wire snips
small needle nose pliers
super glue
Dremel (optional but makes cutting perf-board easy)
small drill bit the size of the motor shaft "mine was 5/64"
Step 2: Making the Light Wand
This is the part that spins around the hat carrying the LED's. I used .025" music wire from the hardware store to make the frame, but it was too weak. When it spins around the centrifugal force bends the wire out of its normal shape. A thin clothes hanger might work better, as long as its thin enough to pass between the leads of the LED's with heat shrink tubing or electrical tape around it to insulate the LED's
Cover about 2 inches of the end of the wire with heat shrink or electrical tape, and then push the LED's over this. (I used a pick to punch holes in a piece of card stock to help space the LED's and hold them in position. Make sure they are all oriented the same direction with the negative pins all on one side. I used super glue to help hold the LED's in place while getting everything soldered up. But be sure not to breathe or get the Super glue fumes in your eyes when soldering. Use good ventilation.
Bend the negative pins over and solder together, attach one wire to the end of this. This will be the common ground point for all of the LED's Make sure to keep this wire separate from the rest. I left mine about twice as long as the others.
Attach one wire to the positive side of each LED. Make sure to scrape off the enamel to get a good solder contact. Leave about 12" long or so, you don't want this to be too short.
Test that each LED lights when batteries are connected to the wires. And then fill in around the LED's with hot glue to hold them in place and to help protect the wires.
Step 3: Making the Circuit Board
Arrange the battery holder, switch, socket, and resistors on the perf-board for the best fit.
I basically used the circuit off of Ladyada's minipov2, http://www.ladyada.net/make/minipov2/hardware.html, except instead of using the programming connector and resistors in that circuit. I used this programmer instead.
I made a jumper that went in between the standard 10pin DAPA programming cable, and the 5 pin header on the board. I got by with using only 5 pins, because I used the internal battery to power the chip during programming.
Step 4: Mounting the Motor and the Circuit to the Hat
First of all you need a hat. I got a cheap $2 plastic derby from the Halloween store. I was originally going to buy a top hat, but changed my mind. Find one that fits well. Mine is actually too small and only sits on top of my head. It actually fits my wife better, but there is no way she is going to wear this crazy contraption.
Find the center of the hat. Luckily mine had a molding mark on the inside, so it was easy to locate.
I also had some very tiny screws that would fit the 2 mounting holes of the motor, so I took a stiff piece of black plastic and drilled mounting holes in it. I hot glued this over the center of the hat on top. (Hot glue is your friend, it hardens very quickly, just keep it off your fingers when hot ;-{ ).
I then attached the motor to this and then ran more hot glue around the motor to make sure it doesn't work loose. mount the switch and the battery holder inside as well. Make sure you leave room for your head.
I found the best place to mount the motor to the circuit board was right under the resistors. There were no wires there, so nothing to get in the way. I cut and super glued a scrap piece of perf-board in this area to build up the thickness, and make sure the motor shaft had a good place to sit. Use the drill bit to enlarge the hole in the perf-board big enough that the motor shaft fits snugly.
Step 5: Mounting the Light Wand to the Circuit Board.
Decide how high the lights are going to be on the side of the hat, and then form the wire to the shape of the hat. Be sure to use the front or back of the hat, due to the hat being oblong. With the circuit board temporarily mounted on the motor shaft, measure, mark and cut the stiff wire to the correct length.
Thread the enameled wires and the mounting wire through shrink wrap tubing, or wrap with electrical tape. Then bend a small hook in the end of the wire at it catches in the holes in the perf-board and keeps it from pulling away when spinning. attach the loose end of the wire to the perf board with some scraps of wire threaded through the holes. and then hot glue in place.
Use a battery to check which enameled wires go to which LED, and then thread them through the top of the board and solder underneath to the appropriate resistor. NOTE: bottom LED attaches to pin 19, top LED attaches to pin 12. When all wires are soldered in place cover the wires and board in hot glue to keep everything in place and to keep the delicate enameled wires from getting snagged.
Once everything is in place, you need to balance the rig as best as you can. If it's not balanced, your hat might just vibrate off your head, or worse fly apart and hit someone admiring your creativeness. Use more hot glue to attach weight where needed. One great thing about hot glue is that you can reheat it to move the weight around. If you end up using a coin, just hold your soldering iron on it until is starts sliding on the glue. Just make sure the metal coin doesn't short out on the resistors. Once everything is balanced, apply superglue to the motor shaft to permanently attach it to the circuit board.
Step 6: Programming the Chip and Fixing the Timing
I wanted the letters to be nearly proportional, so I did the math, found the circumference that the LED's traveled, divided out the distance by the height of the LED's and found out I could have 133 columns of text.
I use this software to generate the code for the text.
Download and install WinAVR so that you can see the C source code of the MiniPOV2 and edit in your own sign.
When I first got the program downloaded into the ATtiny2313, and spun it up, it was so COOL. The only problem was that the motor was spinning to fast for the text. You'll have to go into the code and adjust the part that says "OCR1A = (uint16_t)1000;" and adjust the 1000 to what best suits your motor, and tastes. I had to adjust mine to 1200 to make it slowly spin.
Step 7: Video of the Hat.
Here is a video I took, in several lighting conditions. I apologize for the bad camera work, and not editing it. I don't do videos very often, and don't have the software installed to do it properly.
I didn't notice the text spinning around that fast when I took the video. Normally it just floats around slowly. I don't know if it's the camera, or if it was low batteries in the motor part (I took the better batteries to put in the camera, and grabbed some used ones off of my desk).
Made a second video. Downloaded full height fonts so the text is bigger, Also changed out the batteries for the motor.
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    7 Comments
    I love this hat, Can you tell me what supplies can i get to do a smaller version of your hat for a pet? I would love to try this, I have a fashion show in two weeks. I'm new to all of this so any help would be great. I have purchased some stuff from Sparkfun even a lilypad pro kit lots of LED's s, coin cell battery and holder but, i see that you mention the Mini-POV, is that easy to program? Can someone write what i want my hat to display and can i then cut and paste in the library, i think that is what its called. I have never done any electronics but im so willing to dive in and learn, with a little help. I guess once i learn the basic things it will become easier. Thanks Gladys
    haha! i love it! that works really well. Thanks for sharing.
    btw, the camera wont show the pov properly, as pov relies on the 'slowness' of our eyes, and residual image.
    Thanks for the comment. The camera doesn't do too bad. I messed with the manual shutter speed some. Too slow and it was a blur. Too fast, and it was just a partial text. I changed the batteries and the text slowed its progression around. I thought of adding a sensor, kinda like the SpokePOV, but just didn't. I would still like to rewrite the code some to where it flashes different messages up. Store 2 or three and cycle between them every few seconds. Gotta study C more though. I went from VisualBasic to Javascript and PHP.
    Thanks fo rthe comment. It's not bad comfort wise. The hat is a little small for me (it's the only size they had), so it doesn't sit down on my head right. I balanced the spinner as best I could, and it has just a slight wobble to it. My wife and kids tried it, and said it tickled. I think they could feel the motor more. I've got a hat theme going on for Halloween. One year I built a motorized beanie. Then to top that, I built a Jester's hat one year, where the bells are on the ens, I put ping-pong balls with LED's in them. I used a 4 channel driver chip to make them chase around. I think this one really tops them both. What's cool is I can plug it into my computer and get a new message in about 5 minutes. I'll try to post some more images with different sayings.
