1- Disassemble your pen. 2- Cut the load of the pen to te size you want. 3- Cut the structure of the pen to the thise of the load. 4- Join everything ...
In this tutorial you will learn how to create a cool mini-pen.
What you can do is to remove the rubber end with the metal ball point (and be careful not to lose the metal ball point because it is not secured to the rubber end)
Then cut the ink cartridge to the desired length from the removed pen tip side (not the air bubble side).
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Does/did yours leak too?
Then replace the pen tip.
Hope this helps ;)
vote for it in the big small contest pls :D
Good 'ible though. best of luck in the contest.
