Introduction: Mini Rail Gun
Picture of Mini Rail Gun
This is just a small-scale version of a magnetic rail gun. it moves a set of connected magnets across electrically charged rails. If you had larger magnets and a higher voltage it could bend the connecting bar and be somewhat like a cannon.
supplies:
cardboard
aluminum foil
wire cutters
wire coat hanger
glue
wire
9 volt battery
2 disk magnets
tape
Step 1:
Picture of
Cut your cardboard about 6 inches wide, and 10 inches long. Then glue 2 strips of foil to the cardboard long ways, but not touching. leave about 2 inches hanging of the end of your cardboard.
Step 2:
Picture of
Now, take the 2 wires and attach one end each to the battery using tape. Then take the other free ends and tape them to the ends of the foil.
Step 3:
Picture of
Take your coat hanger and cut a pice that reaches about to the middle of the foil strips, mine is about 3 inches. Now you have to make the ends flat so the magnets will be strait. i used a hammer, but it is probably better to file them down.
Take the magnets and attach them to the ends of the wire. The polarity has to be facing opposite directions.
Step 4: Finished!!
Picture of Finished!!
Set the magnet rail thingy on the foil and it magically moves! if it goes the wrong direction, just start it at the other end. If you don't think its going fast enough, it can be fixed by higher voltage, but don't, it won't be my fault if you hurt yourself. use common scence
j3345 (author)2012-01-07
would it work if you wrapped the magnet in foil if the outside of it doesnt conduct electricity please answer soon
iminthebathroom (author)2010-11-29
Interesting, I have seen other similar science type projects like this where they have aluminum foil to pull static electricity from a CRT screen to power units like this. You get a little more punch with "relative safety"
About This Instructable
5,478views
14favorites
License:
More by ben88b:Mini Rail gun
Add instructable to:
