When I told him that I did not really want to fire up the grill just to make a couple S'mores, he suggested a mini grill. BRILLIANT!
Step 1: Parts and Tools needed
(1) Cedar Plank
(4) Bolts - 1/4 inch and 2 and 1/2 inches tall
(4) Nuts - 1/4 inch
(4) Optional washers for the bolts
(1) 2.5oz Stainless Steel Condiment Cup (Four for 1$ at Wal-Mart)
(1) Box of cheap toothpicks
--NOT PICTURED--
(1) Box of matches
(1) Bag of large marshmallows
(1) Chocolate Bar
(1) Box of graham crackers
(1) Bamboo skewers, normally used for shish kabobs
Tools:
(1) Drill
(1) 2 and 1/2 inch drill bit
(1) 1/4 inch drill bit
(1) Saw
Step 2: Drilling, cutting, and drilling some more
Drill the large hole (2 and 1/2 inch bit) in the center of the cedar and about 1/2 inch away from the outside edge (see pic).
HANDY TIP: Put a scrap board underneath when cutting to prevent the wood from splintering.
Once that hole is drilled, measure about 1/2 inch away from the other side of the whole and cut (see pic).
When that piece is done, drill four holes in the corners with a 1/4 inch drill bit (see pic).
Step 3: Bolt it up and drop in the cup
When that is done, drop the cup in the hole (see pic).
A perfect fit!
Step 4: Fill it with toothpicks, light it up and start toasting marshmallows
OK, now that we have settled that, on to the fire building. I only used a small group of cheap toothpicks (about 20). I broke them in half so they would rest in the bottom of the cup. You do not need the flame too high!
Get your marshmallow prepared by placing it on the end of a bamboo skewer. Place a piece of cholocate on top of a graham cracker. Have the other graham cracker piece ready to be placed on top.
Light the toothpicks with a match. I found that about 20 toothpicks in the cup can toast 2 marshmallows... maybe three, but I like mine nice and toasty (burned).
NOTE: Don't blow on your marshmallow when it's by the mini grill. My son did and it blew the lit toothpicks out of the cup! YIKES!
Once the marshmallow is toasted, place it on top of the chocolate and then put the other half of the graham cracker on top of that. Wait for the chocolate to get nice and melty and then enjoy your S'mores!
When you are done with the mini grill, pick it up by the edge of the cedar and run water into the cup to put out the fire. I also found that there is a pleasant cedar smell given off after using the grill.
ENJOY!
Visit Our Store »
Go Pro Today »
It will produce a big flame with that size of opening but the products of the combustion are harmless - carbon dioxide and water vapour.
Take a look at this mini burner:
http://how2dostuff.blogspot.com/2008_05_01_archive.html
lol
