3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Mini Spud Gun, Classroom Nemesis
Simple, relatively reliable, cheap as dirt miniature spud gun
Parts :
1. Lighter Igniter (Peizo Electric Igniter)
2. Bic Pen
3. Crayola Marker
4. 1/2 in. Screw
5. Generic Hairspray
6. 3 - 5 in. of small wire
Tools :
1. A punch that can make
a hole slightly smaller
than the diameter than
the wire from the igniter
(a thumb tack followed
by a small nail)
Step 1Preperation
Preperation
1. Remove the tip of your Bic pen by biting and pulling or using pliers.
2. Remove end cap ( Be creative, theres no best way, I just cut it off, but make it a clean cut! )
Barrel Is Complete, Set Aside.
3. Remove the felt tip of the Crayola marker ( Messy, dispose of wisely )
4. Punch small hole in the rear of the marker and insert the screw. This will serve as a 'handle' to remove the end cap.
5. Pull, thus removing the end cap of the marker. Do not discard, you will need it.
6. Remove the ink tube inside the marker ( Again, be creative, tweezers, etc., discard of wisely )
7. Poke two small holes 1mm in diameter about 3/4in. from the rear of the marker at the 12 and 6 o'clock.
The Chamber Is Complete, Set Aside.
8. The peizo electric igniter probably is still inside your BBQ Lighter, so we're going to need to remove it with the wires intact.
9. Usually the igniter comes with one wire and a contact pad, if so find another wire about the same thickness and attach to the contact pad. ( Once again, be creative )
10. Strip the ends of the wires leaving about a millimeter of exposed wire.
296 comments
1-40 of 296next »
Sep 19, 2007. 6:50 PMbigdog2729 says:
does the crest bottle do anything like hold more hairspray or anything?
Aug 13, 2010. 12:56 PMDISTURBED1 says:
what other ammo could we use or is it just the little paper things i really wanna make it tho, and the crest bottle could ppl make it out of a diffrent material? like mabey wood? thanks
Feb 15, 2012. 4:42 PMdeckpro101 says:
uhh you can use potato
Sep 24, 2007. 4:21 PMbigdog2729 says:
nah thats more like pretty awesome
Jan 11, 2011. 10:56 AMRGM La Paz says:
dude try some ronsonol lighter fluid super combustible works great dont put to much if u dont wanna blow off ur hand
Apr 10, 2011. 7:30 AMcam.dav32 says:
I put to much hairspray in a combustion gun and fired, for two weeks i had no skin on the left hand side of my right hand.
Feb 15, 2012. 4:40 PMdeckpro101 says:
lol i use axe bcuz hairspray leaves a residue and ond time i fireded my own and it exploded
Jan 14, 2012. 9:18 AMdmcawesome says:
air riffle pellets .22
Feb 1, 2009. 7:38 PMdmcawesome says:
projectiles haha a 50 cal. xD
Jul 15, 2011. 9:41 PMasnyder5 says:
Best projectile for these mini spud guns:
Those tall, skinny Lego antennas. The ones that can flex a little bit. The base of the antenna that interlocks with other Legos is perfectly matched to the inner diameter of a BIC pen tube. Shooting these things is dangerous (these shoot WAY faster than any q-tip; you can't even see them fly they go so fast. I shot one at a fabric couch and it penetrated the whole way to the base of the antenna). The base also acts like a badminton birdie and stabilizes the long, thin antenna in flight.
Jul 13, 2011. 8:10 PMAce156212 says:
PLEASE make an instructable on this!!!
Jul 13, 2011. 5:46 PMAce156212 says:
I've tried firing spitballs, pen tips, airsoft BB's (a bit too small), and a .22 cal bullet (which only went a few feet and much slower). so far spitballs are the best.
Jun 11, 2011. 1:15 PMharry88 says:
if you put rubbing alcohol as fuel it whistles and launches it 1 inch
May 27, 2010. 3:22 PMTappa says:
well.... i made it... its purdy cool and fun to shoot!! but my first time firing it i tryed using Rave hairspray. its flamable so i figurd it would work. and it did barly!! So i decided to find a diffrent propelent. i found out that bug spray for flies and horse flyes works ALOT better.... but remember never put to much of any propelnt in the gun. not because its to powerfull. but because it just wont fire!!!(cuz no oxegen to burn). but the only problem i have with it is that the BBQ ignighter keaps running out of battry! i can maybe get only 8 shots out of one igniter!  is there any other way or thing to use as a igniter???
Jun 1, 2011. 3:58 AMpastaking says:
Get a BBQ Piezo.
May 3, 2011. 1:59 AMboomboy123 says:
epic
Jan 13, 2011. 11:15 AMMrMadmonkey4 says:
lol i made a sniper rifle version of this and its awesome!!!!!!!!!!!!!!
Jan 9, 2011. 12:46 AMafroray says:
lol!
Nov 22, 2010. 6:53 PMcheeksyb says:
me and my brother juss started makin mini potato gun and we both enjoy them but have a hard time finding good ammo...i want something big enough for tacks :) or something strong enough to kill a small animal (squerall or chipmunks) their over populated in michigan!! But this site has helped me and has my interest in makin this a hobby... I plan on making a large one... But I want 1 for snowballs/iceballs as well!!
Oct 3, 2007. 8:33 AMDrStoooopid says:
you have way too much time on your hands.
Sep 9, 2010. 11:14 AMDISTURBED1 says:
i agree with Applecore807
not everything is a "waste of time" or a matter of having too much time on your hands but hes really beating most cavilians and hes not on facebook all day hes doing somthing useful with the time on earth mabey hes like some of us and likes to find out what happens if u mix hairspray and butane with an oxygen level and see what ratio propels farther so i agree with everyone in this convo except you Drstoopid
Apr 22, 2010. 4:17 AMApplecore807 says:
To be honest Drstoopid im sick of people saying that, if you learnt a good english class you'd know that were stuck in a matrix which is a jail that we cant see of touch. This ideology of growing up getting a job pumping a female having a kid and increasing your land property untill you die is quite wrong and hence a matrix. Sure he could do oher things like go to the mall but really he has found something unique and creative and has spent some time  teaching us. Too much time on your hands is very shallow for something that has a deeper meaning.
Mar 24, 2010. 12:35 PMyeolddingdong says:
so wrong mr stupid
Mar 27, 2010. 8:09 PMEnigmaMax says:
maybe he meant you have too many watches.
Jul 28, 2010. 7:37 AMRococotek says:
@EnigmaMax +1
Jun 1, 2011. 3:57 AMpastaking says:
ditto
May 22, 2009. 3:27 PMtim789 says:
i cant find a electric lighter just butane what do i do
Sep 9, 2010. 11:06 AMDISTURBED1 says:
butane will also make a bigger boom therefore more distance
Aug 13, 2010. 12:40 PMDISTURBED1 says:
get one of the long tipped lighters and unscrew the screw in the back inside take wire cutters and cut the wires by the butane follow the cord back thats the thing that makes the spark and obviously when the butane goes past the spark u get fire... sorry didnt mean to give the whole anatomy lol its a very simple thing to do.
Aug 11, 2009. 9:52 PMtoogers says:
go to ace hardware and ask for a grill ignitor, it's the same but bigger and it has a cool red button.
May 24, 2011. 3:46 PMthe gizmoman says:
i got one of those battery powered grill ignitors for a modified spud gun ( it shoots paper rockets )
Jul 23, 2009. 2:29 PMCharles IV says:
Fail...
Sep 2, 2010. 12:00 AMI Ride Kangaroos says:
Pretty nice gun dude!
Aug 30, 2010. 12:02 PMRobot Lover says:
The last gun kinda looks like a p90
Aug 21, 2010. 7:40 AMscience kid says:
That is awesome!
Aug 9, 2010. 2:16 AMelenwaren says:
so many nice
Aug 2, 2010. 12:08 PMD5quar3 says:
does the lighter do anything besides make it look like a banana clip
Jun 4, 2010. 8:57 PMteslafan100 says:
lol.funny
1-40 of 296next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:Grim
