loading
Cool
But this an't my idea.
Step 1: The Gun
It's pretty obvious.
you need...
tiny advil pill bottle
--2 tacks
-pen tube
-bbq ignighter(inside a utility lighter)
-wire
-electric tape
Step 2: Build
Cut the end off the pill bottle(the end without a cap).Stick in the two tacks into the bottle and make it so they almost touck(like a 3mm gap). Take a wired up ignighter and strip the ends and wrap them around each steel part of the tack and push down(if you dont know how to wire the ignighter too bad!).Tape the ignighter down to the bottle(make shure you can still press the botton).Wrap tape to the end of the pen tube so it snugly fits into the cut end of the bottle.Test for a good spark(rewire if it wont spark).
Put a bit of potato in the pen tube. spray a bit of hair spray in the screw end and put on the cap.
fire and enjoy
Ps. this is my 1st instructable tell me what u think.
Step 3: Original
Step 4: Nothing
I was just wondering, would the pill bottle start melting due to the fact that things are exploding in it?
Guys What about hand sanitizer??
can we use perfume instead of hairspray?
u can use body detorant as well like axe or something
COOL :D
most perfume isnt flammable though<br>
made one, heres a pic.
Damn, i was playing with it last night and it self destructed. Did you know you can make a flamethrower from this and the fuel can? It's simple. spray a shot of fuel in the cannon, dont close the end, then ignite it. Then spray deodorant across the flames coming from the bottle.
i used a m&m mini bottle and it doesn't seem to work does anyone know if there is a problem
does the back pop open cuz it dosent close very good
well maby , cuz its such a small chamber, u flouded the chamber by sprayin/pourin in to much fuel.
heres mine, its the cricket
Pls do me a favor: anybody who does this... Do not use a 2 liter bottle instead of the pill bottle... Thank you
LOL, Does this request stem from personal experience?
According to the diagram the ammunition/piece of potato is to the <strong>front</strong> of the barrel. If you'd like to gain more distance you can push it further down the barrel. Just a tip.<br/>
Not necessarily. The farther it is pushed back, the more energy that is needed to push it down the barrel, thus the less energy that is left to project it. However, if you put it in the very front of the barrel, it would be very inaccurate. You simply have experiment and find a good place to push the projectile that's a good balance between distance and accuracy, it all depends on the shape and weight of the object.<br />
You're right, you may waste energy pushing it all the way down, but that would be your own fault for using a projectile that would not leave the barrel cleanly. I'll admit I don't use a normal mini spud gun a lot, but in my experience with advanced, scale spud guns so far it's best pushing it all the way down.
Or just use airsoft pellets, and put one of the stoppers that's normally in an airsoft gun, this way u don't need a ramrod. I did this, put a pistol grip onbit, and made it a shotty attachment for my panther a15.
instead of a bbq igniter, can you use the sparky&nbsp;end of one of those long lighters(an empty on)?
yes
open that lighter up and you will find the same igniter<br /> <br />
ahh thnx
great for class! awsome<br />
Anyone know how to do step 4???
i know, stare at the screen and the ~~dots~~ periods for at least 3 ~~minuates~~ ~~manuaters~~ ~~minutse~~ minutes on the ~~fourh~~ fourth step then you ~~cant~~ can do whatever (rob a bank,steal a car whit the spud gun)
Cool. but uh....... wats my ignition if i dont hav a BBQ lighter?
if you use too small of a bottle the fuel-oxygen ratio will be VERY hard to get right. It makes a biger boom and is more reliable to use bigger bottles. If you want to see a manly spitball cannon check out my instructible by clicking on my name !
Dont tease me but wat the hell is a spud gun???!!!!!!
A spud gun is a gun that egnights a small amount of fuel using a spark. This ignition causes a build in pressure that forces out a piece of potato in the guns barrel.
You did really good for your first instructable. Keep it up!
Thanks.
ok i made the gun but i cant get it to shoot can some1 help me i did do one thing different, instead of the tape around the barrel i drilled a hole and i glued around the edges would that be the problem? ill apreaciate the help
you most likely are just flooding the chamber with too much fuel. You may have you diodes too far apart. Or, you have too big/small of a blast chamber.
This is a great instructable (even if it wasnt your idea) i just finished making this mini spud gun and it worked perfectly. I used a Herron mini 25 capsule pack though, so there isnt alot of power but still it works well. Good Job!!
is there any way that you can fire it without the lighter igniter
i did it, go to this link:<br/><a rel="nofollow" href="https://www.instructables.com/id/how-to-make-an-Oust-powered-mini-spud-gun/">https://www.instructables.com/id/how-to-make-an-Oust-powered-mini-spud-gun/</a><br/>
already done on techblog.
Yepper
eh...okay. So that`s how it`s done...
i tried it but the problem i had was that the pill bottle was too small and when i sprayed the hairspray it would condense and wouldnt ignite. so i used a baby formulda thingie(a bit bigger) and it worked alrite
some picts of the built gun and the steps would be good to add peace out
I just saw that video that u have there. it is a good idea, but it seems to me that if you could get an airsoft bb in there that it would work much better. ill try to build one, i know where theres a gluestick my brother wont miss lol
About This Instructable
81,594views
34favorites
License:
More by A_squared:Tin Can Lamp! Yay! Metal, Oil Burning Candle Mini Spud Gun
Add instructable to:
