Introduction: Stackable Toy Boxes
Step 1: What You Need
This is what you need if you are doing the bigger box...for my daughter I would be doing the cube...it's the same except there are no wheels. I would continue this instructable with the cube and post pictures of the bigger box later as i couldn't complete it.(my neighbor complained of the sanding noise so I'm waiting for the couple to leave on a nice long weekend!)
Step 2: Build the Box
Build a basic box...make sure it's square else it would not stack. Remember to first cut the slots for the finger hold. To cut the slots find the center point. Then mark 2 inches from the dot on either side. drill through on both ends...draw lines on the upper and lower curve and cut away with a jigsaw or band saw.
cut 2 square dowels the width of the finger hold planks...pass it through the box to make sure it would fit...then fix it at the bottom...you may glue,nail or do both!
Step 3: The Fun Part- Texturing and Painting
Prime/ gesso the boxes...giving it a textured background hides a lot of mistakes...plus children just love this part.
For more ideas on texturing check out the below instructable
https://www.instructables.com/id/Sculpturing-and-Texturing/
Paint and decorate how you like...I of course went for the rainbow colors.
Cut numbers in a mirror sticker and paste on one side...you can put on the other side pictures of what you want inside the box
Step 4: Ta Da!
Now varnish and let your kids enjoy organizing! It's fun stacking them up...it could be giant number blocks :-)
Step 5: Some Rainbow Thyme Ideas
Here are some links to some rainbow theme ideas
Coat rack https://www.instructables.com/id/Personalized-Mosaic-Coat-Rack/
Clock https://www.instructables.com/id/Rainbow-clock/
Foam Wall decor frames https://www.instructables.com/id/Foam-wall-decore-and-frames/
Rainbow book shelf https://www.instructables.com/id/Build-a-READING-RAINBOW-Book-Shelf/
Bulletin Board https://www.instructables.com/id/Bulletin-board/
Finalist in the
Maker Moms Contest
Hurricane Lasers Contest
Fix & Improve It Contest
