Mini Succulent Stud Earrings
Introduction: Mini Succulent Stud Earrings
My apartment is full of succulents, since everyone living there forgets to water the plants. Still, we've had a few close calls with almost killing our succulents, but we like having plants around. These are perfect, since they'll never die and you can take them with you wherever you go!
  • Polymer clay, in green and another color.
    • Here I used the yellow-green from Sophie and Toffee's original formula of clay, and Sculpey III in silver. Granite might also be a nice color for this.
  • A needle tool
  • E6000 glue
  • Earring posts
  • An oven
  • A bottle of acrylic paint, or something similar to use as a platform to sculpt on
  • Glaze (I like varathane polyurethane!)
  • Any other findings (bails, ring bases)
Step 1: Creating the Base
Take a tiny ball of silver clay and flatten.
Step 2: Making Your Leaves
Taking a tiny ball of green clay, shape it into a teardrop. Using your needle tool, make a light indent at the center of the leaf.
Fold the leaf in half, and pinch together to shape the leaf.
Repeat this to make approximately 10 more leaves, and again 5 more times with slightly smaller leaves.
Step 3: Layer 1: Attaching Your Leaves
Using your needle, start placing the leaves on your base, pressing in with the needle to blend the clay together securely.
Repeat this with your first 10 or so leaves, until you complete making leaves around the entire base.
Step 4: Layer 2: More Leaves!
Now you're on your second leaf layer! :D
Using the 5 smaller leaves, repeat step 3, overlaying your leaves on top of the first layer. I find that using 5 leaves is just enough to fill in this space, and it looks more natural, but you can use however many you want.
Step 5: Filling in Gaps
Now, you might notice that there's now a gap in the center of your succulent. This step will fix that!
Roll out a tiny, tapered snake of clay, and flatten
Roll this up to form a tiny rose-like swirl.
Use your needle to place this at the center of your leaves. You can use a bit of liquid clay to 'glue' this in place.
Step 6: Baking!
Bake according to your clay packaging directions. Typically it tends to be around 275°F or 130°C, but be sure to read the directions on your clay specifically. The clay I'm using here bakes at 120°-130°C, slightly lower than the regular temperature.
TIP: Be careful to bake your clay thoroughly. Under-baking causes crumbly clay! Also watch your oven and beware of burning!
Step 7: Putting It All Together
Now you should have your 2 mini succulents, earring posts, and E6000 glue.
Put a tiny drop of glue onto your earring post, and put this on your mini succulent. Wait about 20 minutes for it to dry.
Step 8: Variations
And now you're done! You can glaze these if you want them to look shinier.
I also made a succulent to glue to a bail to make a succulent necklace pendant! These could also be glued onto ring bases. Make a whole set of succulent jewelry!
    • Paper Contest 2018
      Paper Contest 2018
    • Trash to Treasure
      Trash to Treasure
    • Pro Tips Challenge
      Pro Tips Challenge
    Can we please see one of them worn?
    Would be just the thing for a doll house as well, just make small "clay" pots for them :)
    Probably, when I've figured out how to take a picture of it with a dslr :D (>_< I have a t5, which doesn't have the screen you can flip over)
    Yes, definitely it could work for a dollhouse!
    Frame an area and use a remote (or self timer) to shoot when you're in the area, use the T5 + a mirror, use a webcam, involve a friend - it's easier than writing that you cant ;-P :)
    No, actually it isn't easier. I'm a student working over summer at my school, and commute for hours only once or twice a month to go home. I don't take the things I make with me to school, so I literally can't take a picture of someone wearing them at the moment, but I still like to timely respond to comments on things I post (from my huge backlog of pictures :P ).
    I didn't want it to seem like I was ignoring your comment and responding to others :)
    Aha - no worries and don't burn yourself out :)
    They're really well made and you show how to do it very explicit - super nice.
    Have a nice day :)
    These look just like real succlents.
    This is ridiculously impressive! I don't think my fingers can work on this scale . . . very impressed! :)
